Datasheet Texas Instruments TS5A4594DCKR — Даташит
СерияTS5A4594
МодельTS5A4594DCKR
Одноканальный аналоговый переключатель SPST 8 Ом 5-SC70 от -40 до 85
TS5A4594 datasheet
PDF, 879 Кб, Файл опубликован: 20 дек 2004
Pin555
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаJSRJS5JSF
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
Полоса частот450 МГц
Bandwidth(Max)450 МГц
Configuration1:1 SPST
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)20 мА
Input/Output OFF-state Capacitance(Typ)6.5 пФ
Input/Output ON-state Capacitance(Typ)13 пФ
Количество каналов1
OFF-state leakage current(Max)0.005 мкА
ON-state leakage current(Max)0.01 мкА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Ron(Max)20 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)0.5 uA
Supply Current(Typ)0.01 uA
Supply Range5.5 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)2.7 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
На английском языке: Datasheet Texas Instruments TS5A4594DCKR
