Datasheet Texas Instruments ISO7330FCQDWQ1 — Даташит
СерияISO7330-Q1
МодельISO7330FCQDWQ1
Автомобильный, маломощный, трехканальный цифровой изолятор 3/0 16-SOIC от -40 до 125
ISO733x-Q1 Robust EMC, Low Power, Triple-Channel Digital Isolators datasheet
PDF, 1.3 Мб, Файл опубликован: 16 ноя 2015
Pin16
Package TypeDW
Package QTY40
МаркировкаISO7330FCQ
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Data Rate(Max)25 Mbps
Default OutputLow
Forward/Reverse Channels3/0
Integrated Isolated PowerNo
Isolation Rating3000 Vrms
Количество каналов3
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Время задержки распространения31 нс
Propagation Delay(Typ)31 нс
RatingAutomotive
Surge Voltage Rating6000 Vpk
VCC(Max)5 В
VCC(Min)3.3 В
  • Evaluation Modules & Boards: ISO7341CEVM
    ISO7341CEVM Quad-Channel, Digital Isolator Evaluation Module
  • Evaluation Modules & Boards: ISO7310C-EVM
    ISO7310C-EVM: Single-Channel Digital Isolator Evaluation Module
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Semiconductors > Isolation > Digital Isolators
На английском языке: Datasheet Texas Instruments ISO7330FCQDWQ1
