Datasheet Texas Instruments LM36923HYFFR — Даташит
СерияLM36923H
МодельLM36923HYFFR
Высокоэффективный трехструнный драйвер белого светодиода 12-DSBGA от -40 до 85
LM36923H Highly Efficient Triple-String White LED Driver datasheet
PDF, 2.0 Мб, Версия: B, Файл опубликован: 7 окт 2016
Pin12
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка36923H
Width (мм)1.16
Length (мм)2
Thickness (мм)1.6
Pitch (мм).4
Max Height (мм).625
Количество каналов3
Duty Cycle(Max)92 %
LED30
LED Current Per Channel30 мА
Package GroupDSBGA
Peak Efficiency92 %
Shutdown Current(Typ)1.2 uA
Special FeaturesAdjustable Switch Frequency,CABC,Direct PWM Dimming,Enable/Shutdown,I2C Control,OVP,Thermal Shutdown
Switching Frequency(Max)1050 kHz
TopologyBoost,Current Sink,Multi-Channel
ТипInductive
Vin(Max)5.5 В
Vin(Min)2.5 В
Vout(Max)37 В
  • Evaluation Modules & Boards: LM36923HEVM
    LM36923H Highly Efficient Triple-String White LED Driver Evaluation Module
  • Evaluation Modules & Boards: LM36922EVM
    LM36922 Highly Efficient Dual-String White LED Driver Evaluation Module
  • Auto-Frequency Mode Setting for Improved Boost Efficiency in White LED Backlight
    PDF, 252 Кб, Файл опубликован: 14 окт 2016
    As the load current of a boost converter is reduced, the ratio of conduction losses to switching lossesbegins to lower. Conduction losses are losses that are a function of current. Switching losses are lossesthat are a function of switching frequency. As this ratio is reduced the boost switching losses begin todominate the total circuit losses. When this happens, the benefit of lowering the
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: LM36923H (1)
  • LM36923HYFFR
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments LM36923HYFFR
