Datasheet Texas Instruments UC494ACJ — Даташит
Серия | UC494A |
Модель | UC494ACJ |
Расширенные регулирующие широтно-импульсные модуляторы 16-CDIP
Datasheet
Pin | 16 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Width (мм) | 6.92 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- DN-38 Unique "Cheap and Dirty" Converter for Low Power Bias SuppliesPDF, 65 Кб, Файл опубликован: 5 сен 1999
The UC495A PWM modulator provides a complete pulse-width modulation system in a single monolithic integrated circuit. Most-power supply designs use PWM controller ICs and MOSFET switches that require 10-15V bias supplies for proper operation. A common application problem is to first generate an auxiliary supply within this range. Although simple in many applications, developing this supply with a
Серия: UC494A (5)
- UC494ACJ UC494ACN UC494AJ UC494AJ883B UC494AN
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
