Datasheet Texas Instruments THS6002IDWP — Даташит
СерияTHS6002
МодельTHS6002IDWP
Двойной дифференциальный линейный драйвер/приемник 20-SO PowerPAD от -40 до 85
Dual Differential Line Drivers And Receivers datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 15 мар 2007
Pin20
Package TypeDWP
Industry STD TermHSOIC
Package QTY25
МаркировкаTHS6002I
Width (мм)7.52
Length (мм)12.82
Thickness (мм)2.55
Max Height (мм)2.65
2nd Harmonic70 dBc
3rd Harmonic80 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCurrent FB
BW @ Acl140 МГц
CMRR(Min)62 дБ
CMRR(Typ)70 дБ
GBW(Typ)140 МГц
Input Bias Current(Max)9000000 pA
Iq per channel(Max)13 мА
Iq per channel(Typ)11.5 мА
Количество каналов4
Offset Drift(Typ)20 uV/C
Output Current(Typ)500 мА
Package GroupSO PowerPAD
Package Size: mm2:W x L20SO PowerPAD: 133 mm2: 10.405 x 12.825(SO PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)1000 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.8 нВ/rtГц
Vn at Flatband(Typ)1.7 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)4 мВ
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
Серия: THS6002 (4)
На английском языке: Datasheet Texas Instruments THS6002IDWP
