Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UC3841N — Даташит
СерияUC3841
МодельUC3841N
Программируемый автономный ШИМ-контроллер 18-PDIP от 0 до 70
Programmable, Off-Line, PWM Controller datasheet
PDF, 937 Кб, Файл опубликован: 5 сен 1999
Pin18
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY20
МаркировкаUC3841N
Width (мм)6.35
Length (мм)22.48
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodPeak Current Mode
Duty Cycle(Max)100 %
Frequency(Max)500 kHz
Frequency(Min)26 kHz
Gate Drive(Typ)1 A
Package GroupPDIP
Special FeaturesError Amplifier,Multi-topology,Soft Start,Synchronization Pin
TopologyBoost,Buck,Buck-Boost,Flyback,Forward
UVLO Thresholds On/Off8/7.8 В
Vin(Max)400 В
Vin(Min)8 В
  • DN-28 UC3840/UC3841/UC3851 PWM Controllers - Summary of Functions & Differences
    PDF, 22 Кб, Файл опубликован: 5 сен 1999
    The UC3840/UC3841 and UC3851 PWM controllers incorporate numerous protection features for switch mode power supplies. The list includes programmable undervoltage lockout thresholds, programmable current-limit thresholds, overvoltage protection, soft-start, and external stop/reset capability. While these controllers are similar in concept, there are subtle differences among them in the operation of
  • Conditioning a Switch-mode Power Supply Current Signal Using TI Op Amps
    PDF, 61 Кб, Файл опубликован: 23 мар 2000
    The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp.
Серия: UC3841 (3)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3841N
