Datasheet Texas Instruments 5962-8761901EA — Даташит
| Серия | UC1707 |
| Модель | 5962-8761901EA |
Дополнительные высокоскоростные драйверы питания 16-CDIP от -55 до 125
Dual Channel Power Driver datasheet
PDF, 973 Кб, Версия: B, Файл опубликован: 16 сен 2008
9 предложений от 9 поставщиков Драйвер FET, MOSFET DRVR 1.5A 2Out High Speed Inv/Non-Inv 16Pin CDIP | |||
| 5962-8761901EA Texas Instruments | 785 ₽ | ||
| 5962-8761901EA Texas Instruments | 1 583 ₽ | ||
| 5962-8761901EA | по запросу | ||
| 5962-8761901EA Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Width (мм) | 6.92 |
| Length (мм) | 19.56 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Fall Time | 40 нс |
| Основные особенности | Analog Shutdown with Optional Latch,Thermal Shutdown |
| Input Threshold | TTL |
| Input VCC(Max) | 40 В |
| Input VCC(Min) | 5 В |
| Количество каналов | 2 |
| Рабочий диапазон температур | от -55 до 125 C |
| Package Group | CDIP |
| Peak Output Current | 1.5 A |
| Power Switch | MOSFET |
| Prop Delay | 100 нс |
| Rating | Military |
| Rise Time | 40 нс |
| RoHS | See ti.com |
- U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching CharacteristicsPDF, 573 Кб, Файл опубликован: 5 сен 1999
The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola - U-137 Practical Considerations in High Performance MOSFET IGBT and MCT GatePDF, 244 Кб, Файл опубликован: 5 сен 1999
The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad - U-111 Practical Considerations in Current Mode Power SuppliesPDF, 787 Кб, Файл опубликован: 5 сен 1999
This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included.
Серия: UC1707 (7)
- 5962-87619012A 5962-8761901EA UC1707J UC1707J/80313 UC1707J883B UC1707L UC1707L883B
- Semiconductors > Space & High Reliability > Power Management Products > MOSFET and IGBT Gate Driver
59628761901EA, 5962 8761901EA
