Datasheet Texas Instruments TMS320C6748EZWT4 — Даташит
СерияTMS320C6748
МодельTMS320C6748EZWT4
Процессор цифровых сигналов с фиксированной/плавающей запятой 361-NFBGA от 0 до 90
TMS320C6748 Fixed- and Floating-Point DSP datasheet
PDF, 2.0 Мб, Версия: G, Файл опубликован: 31 янв 2017
Pin361361361
Package TypeZWTZWTZWT
Industry STD TermNFBGANFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY909090
МаркировкаC6748EZWT450TMS320
Width (мм)161616
Length (мм)161616
Thickness (мм).9.9.9
Pitch (мм).8.8.8
Max Height (мм)1.41.41.4
ApplicationsCommunications and Telecom,Machine Vision
DRAMLPDDR,DDR2
DSP1 C674x
DSP MHz375,456 Max.
Display Options1
EMAC10/100
I2C2
On-Chip L2 Cache256 KB
Operating SystemsSYS/BIOS
Рабочий диапазон температурот -40 до 105,-40 до 90,0 до 90 C
Other On-Chip Memory128 KB
SATA1
SPI2
UART3 SCI
USB2
    XDS200 USB Debug Probe
  • Development Kits: TMDSLCDK6748
    TMS320C6748 DSP Development Kit (LCDK)
  • Development Kits: TMDSLCDK138
    OMAP-L138 Development Kit (LCDK)
  • TMS320C6748/46/42 Complementary Products
    PDF, 26 Кб, Файл опубликован: 20 июл 2009
    This article has been contributed to the TI DaVinciв„ў and OMAPв„ў Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://tiexpressdsp.com/index.php/C6748/46/42_Complementary_Products .This Wiki article serves as a repository of complimentary devices tha
  • Using the TMS320C6748/C6746/C6742 Bootloader (Rev. F)
    PDF, 1.6 Мб, Версия: F, Файл опубликован: 23 янв 2014
    This application report describes various boot mechanisms supported by the C6748/C6746/C6742 bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, def
  • TMS320C6748/46/42 Power Consumption Summary
    PDF, 19 Кб, Файл опубликован: 30 авг 2010
    This article discusses the power consumption of the Texas Instruments C6748/46/42. Power consumption on the C6748/46/42 devices are highly application-dependent. The low-core voltage and other power design optimizations allow these devices to operate with industry-leading performance, while maintaining a low power-to-performance ratio.The power data presented in this document are based on mea
  • TMS320C674x/OMAP-L1x Processor Security
    PDF, 29 Кб, Файл опубликован: 8 июн 2011
    The generic secure environment is supported by hardware within the C674x DSP core. This allows critical code to be executed in a secure environment, hiding sensitive information from the outside world with the help of the following hardware features:Secure thread support – hardware support that allows trusted code to be executed from secure ROMor secure RAM.Protected transition
  • Powering the TMS320C6742, TMS320C6746, and TMS320C6748 With the TPS650061
    PDF, 312 Кб, Файл опубликован: 19 дек 2011
    This document details the design considerations of a power solution for the TMS320C742,TMS320C6746, and TMS320C6748 (TMS320C6742/C6746/C6748) low-power application processor witha TPS650061, three-rail power management unit (PMU) or power management integrated circuit (PMIC).Portable application solution size demands a high level of integration and the TMS320C6742/C6746/C6748 requires at l
  • OMAP-L132/L138, TMS320C6742/6/8 Pin Multiplexing Utility (Rev. B)
    PDF, 37 Кб, Версия: B, Файл опубликован: 27 сен 2013
    The OMAP-L1x8 and C6742/6/8 devices use a great deal of internal pin multiplexing to allow the most functionality in the smallest and lowest cost package. This software allows the pin multiplexing registers of the device to be calculated with ease, as well as showing what peripherals can be used together and what devices support the peripherals that are selected. This software is useful to anyone
  • Medium Integrated Power Solution Using a Dual DC/DC Converter and an LDO (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, or OMAP-L132/L138 processor. Using sequenced power supplies, this reference design describes a system having a 3.3-V input voltage and a high-efficiency dc/dc converter with integrated FETs for a small, simple design.Sequenced power supply architectures are becoming commonplace in high-performan
  • Simple Power Solution Using LDOs (Rev. B)
    PDF, 150 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This reference design helps those desiring to design-in the TMS320C6742, TMS320C6746, TMS320C6748, and OMAP-L132/L138. This design, employing sequenced power supplies, describes asystem with an input voltage of 3.3 V, and uses LDOs for a small, simple system.Sequenced power supply architectures are becoming commonplace in high-performance microprocessor and digital signal processor (DSP) syste
  • High-Vin, High-Efficiency Power Solution Using DC/DC Converter With DVFS (Rev. C)
    PDF, 266 Кб, Версия: C, Файл опубликован: 29 авг 2011
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, or OMAP-L132/L138 processor. Using sequenced power supplies, this reference design describes a system having a 12-V input voltage and a high-efficiency dc/dc converter with integrated FETs and dynamic voltage and frequency scaling (DVFS) for a small, simple design.Sequenced power supply architec
  • TMS320C6748/46/42 & OMAP-L1x8 USB Upstream Device Compliance Testing
    PDF, 1.1 Мб, Файл опубликован: 17 авг 2009
    This application report describes the TMS320C6748/46/42 and OMAP-L1x8 electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The on-the-go (OTG) controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS) and low-speed (LS).
  • High-Integration, High-Efficiency Power Solution Using DC/DC Converters w/DVFS (Rev. A)
    PDF, 208 Кб, Версия: A, Файл опубликован: 5 май 2010
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, OMAP-L138 or AM18x processor. Using sequenced power supplies, this reference design describes a system having a 12-V input voltage and a high-efficiency dc/dc converter with ntegrated FETs and dynamic voltage and frequency scaling (DVFS) for a small, simple design.Sequenced power supply archit
  • TMS320C6748/46/42 & OMAP-L132/L138 USB Downstream Host Compliance Testing
    PDF, 3.6 Мб, Файл опубликован: 17 авг 2009
    This application report describes the TMS320C6748/46/42 and OMAP-L1x8 embedded Host electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The OTG controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS) and low-speed (LS).
  • High-Efficiency Power Solution Using DC/DC Converters With DVFS (Rev. A)
    PDF, 161 Кб, Версия: A, Файл опубликован: 5 май 2010
  • Processor SDK RTOS Audio Benchmark Starter Kit
    PDF, 530 Кб, Файл опубликован: 12 апр 2017
    The TI TMS320C6000в„ў Digital Signal Processors (DSPs) have many architectural advantages that make them ideal for computation-intensive real-time applications that are commonly used in audio processing application. This application notes describes Audio Benchmark Starterkit software that is intended to provide an easy and quick way to benchmark key audio functions on C66x and C674x DSP device
  • TMS320C674x/OMAP-L1x USB Compliance Checklist
    PDF, 89 Кб, Файл опубликован: 12 мар 2009
    This application report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • OMAP-L1x/C674x/AM1x SOC Architecture and Throughput Overview
    PDF, 19 Кб, Файл опубликован: 12 фев 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/OMAP-L1x/C674x/AM1x_SOC_Architecture_and_Throughput_Overview. This collection of Wiki articles provide i
  • TI DSP Benchmarking
    PDF, 62 Кб, Файл опубликован: 13 янв 2016
    This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms.
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > C674x DSP
На английском языке: Datasheet Texas Instruments TMS320C6748EZWT4
