Datasheet ТI REG113NA-3.3/250 — Даташит
| Серия | REG113 |
| Модель | REG113NA-3.3/250 |
400 мА, малошумящий регулятор с малым падением напряжения 5-SOT-23 от -40 до 85
DMOS 400mA Low-Dropout Regulator datasheet
PDF, 965 Кб, Версия: D, Файл опубликован: 8 сен 2005
- LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Thisapplicationreportexplainsthe differencebetweennoiseand PSRRof an LDO.It also explainsthedifferentwaysnoiseis specifiedin LDOdatasheetsandwhichspecificationshouldbe usedin theapplication.Finallyit explainshow LDOnoiseis reduced. - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - Packaging Limits Range of Linear RegulatorsPDF, 75 Кб, Файл опубликован: 8 май 2010
The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
Серия: REG113 (28)
- REG113EA-2.5/250 REG113EA-2.5/250G4 REG113EA-2.5/2K5 REG113EA-2.5/2K5G4 REG113EA-3.3/250 REG113EA-3.3/2K5 REG113EA-3/2K5 REG113EA-3/2K5G4 REG113EA-5/250 REG113EA-5/250G4 REG113EA-5/2K5 REG113EA-5/2K5G4 REG113EA33250G4 REG113NA-2.5/250 REG113NA-2.5/250G4 REG113NA-2.5/3K REG113NA-2.85/250 REG113NA-2.85/3K REG113NA-3.3/250 REG113NA-3.3/250G4 REG113NA-3.3/3K REG113NA-3/250 REG113NA-3/250G4 REG113NA-3/3K REG113NA-3/3KG4 REG113NA-5/250 REG113NA-5/250G4 REG113NA-5/3K
REG113NA3.3/250, REG113NA 3.3/250
