Datasheet Texas Instruments SN74LVCHR16245AGR — Даташит
СерияSN74LVCHR16245A
МодельSN74LVCHR16245AGR
16-битный шинный трансивер с выходами с 3 состояниями 48-TSSOP от -40 до 125
SN74LVCHR16245A 16-Bit Bus Transceiver With 3-State Outputs datasheet
PDF, 1.0 Мб, Версия: Q, Файл опубликован: 12 окт 2014
43 предложений от 18 поставщиков
Интегральные микросхемы Логические микросхемы - Буферы, Приемники, Приемопередатчики
SN74LVCHR16245AGR
от 22 ₽
SN74LVCHR16245AGR
53 ₽
SN74LVCHR16245AGR
70 ₽
SN74LVCHR16245AGR
145 ₽
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVCHR16245A
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)-12/12 мА
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)12.5,9.5,5.7,4.8 нс
  • Simultaneous-Switching Performance of TI Logic Devices (Rev. B)
    PDF, 378 Кб, Версия: B, Файл опубликован: 23 фев 2005
    Simultaneous-switching noise can generate and propagate glitches in electronic systems. Therefore, system designers are faced with challenges to minimize simultaneous-switching noise, while increasing switching speed and improving signal quality. This report presents the performance of different TI logic devices under various simultaneous-switching conditions. Factors such as the number of bits sw
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVCHR16245AGR
