Datasheet Texas Instruments THS6032IVFPG4 — Даташит
| Серия | THS6032 |
| Модель | THS6032IVFPG4 |
Драйвер линии центрального офиса ADSL с низким энергопотреблением 32-HLQFP от -40 до 85
Low-Power ADSL Central-Office Line Driver datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 25 авг 2009
| THS6032IVFPG4 | по запросу | ||
| THS6032IVFPG4 Texas Instruments | по запросу | ||
| Pin | 32 |
| Package Type | VFP |
| Industry STD Term | HLQFP |
| JEDEC Code | S-PQFP-G |
| Width (мм) | 7 |
| Length (мм) | 7 |
| Thickness (мм) | 1.4 |
| Pitch (мм) | .8 |
| Max Height (мм) | 1.6 |
| Mechanical Data | Скачать |
| 2nd Harmonic(dBc) | 79 |
| 3rd Harmonic(dBc) | 68 |
| @ MHz | 1 |
| Acl, min spec gain(V/V) | 1 |
| Additional Features | Shutdown |
| Approx. Price (US$) | 5.65 | 1ku |
| Архитектура | Current FB |
| BW @ Acl(MHz) | 100 |
| CMRR(Min)(dB) | 64 |
| CMRR(Typ)(dB) | 72 |
| GBW(Typ)(MHz) | 100 |
| Input Bias Current(Max)(pA) | 9000000 |
| Iq per channel(Max)(mA) | 10.8 |
| Iq per channel(Typ)(mA) | 8.3 |
| Number of Channels(#) | 2 |
| Offset Drift(Typ)(uV/C) | 10 |
| Operating Temperature Range(C) | -40 to 85 0 to 70 |
| Output Current(Typ)(mA) | 440 |
| Package Group | HLQFP |
| Package Size: mm2:W x L (PKG) | 32HLQFP: 81 mm2: 9 x 9(HLQFP) |
| Rail-to-Rail | No |
| Rating | Catalog |
| Slew Rate(Typ)(V/us) | 1200 |
| Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 32 |
| Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 10 |
| Vn at Flatband(Typ)(nV/rtHz) | 2.4 |
| Vos (Offset Voltage @ 25C)(Max)(mV) | 5 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Active Output Impedance for ADSL Line DriversPDF, 636 Кб, Файл опубликован: 26 ноя 2002
Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS6032 (5)
- THS6032CDWP THS6032IDWP THS6032IDWPR THS6032IGQER THS6032IVFPG4
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
