Datasheet Texas Instruments OPA1632DGNR — Даташит
СерияOPA1632
МодельOPA1632DGNR
Полностью дифференциальный аудиоусилитель ввода-вывода 8-MSOP-PowerPAD от -40 до 85
OPA1632 High-Performance, Fully-Differential Audio Operational Amplifier datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 29 окт 2015
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
Маркировка1632
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
Additional FeaturesBurr-Brownв„ў Audio,Shutdown
АрхитектураVoltage FB
CMRR(Typ)90 дБ
GBW(Typ)180 МГц
Input Bias Current(Max)200000 pA
Iq per channel(Max)17.1 мА
Iq per channel(Typ)14 мА
Количество каналов1
Output Current(Typ)85 мА
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)50 V/us
THD + N @ 1 kHz(Typ)0.000022 %
Total Supply Voltage(Max)30 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.3 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Evaluation Modules & Boards: ADS1282EVM-CVAL
    ADS1282-SP Radiation Tolerant Evaluation Module
  • Evaluation Modules & Boards: TPA3221EVM
    TPA3221 100W Stereo/ 200W Mono HD Analog-In Class-D Amplifier Evaluation Module
  • Using infinite-gain, MFB filter topology in fully differential active filters
    PDF, 571 Кб, Файл опубликован: 14 июл 2009
  • Analysis of fully differential amplifiers
    PDF, 295 Кб, Файл опубликован: 11 мар 2005
  • Q3 2009 Issue Analog Applications Journal
    PDF, 2.1 Мб, Файл опубликован: 14 июл 2009
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
  • Designing for low distortion with high-speed op amps
    PDF, 277 Кб, Файл опубликован: 2 мар 2005
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Audio Op Amps
На английском языке: Datasheet Texas Instruments OPA1632DGNR
