Datasheet Texas Instruments TPS5602IDBTR — Даташит
СерияTPS5602
МодельTPS5602IDBTR
Синхронный понижающий контроллер с двумя выходами и широким диапазоном входного напряжения 30-TSSOP от -40 до 85
Dual, Fast, High Efficiency Controller For DSP Power datasheet
PDF, 949 Кб, Файл опубликован: 28 июн 1999
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY2000
МаркировкаPU5602
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • Using the TPS5602 to Power DSPs (Rev. A)
    PDF, 64 Кб, Версия: A, Файл опубликован: 7 мар 2000
    The synchronous buck converter controllers (TPS56100, TPS56300, TPS56xx, and TPS5602) made by Texas Instruments are specifically designed to provide excellent transient response and high efficiency to the microprocessor power applications such as the TMS320C6000 and TMS320C5000 families from TI, as well as similiar digital loads. In addition, hysteresis control method is used such that power suppl
  • Voltage Regulator Solutions for Xilinx Virtex E Dual Voltage FPGAs
    PDF, 77 Кб, Файл опубликован: 13 июн 2000
    This application report serves as a reference for engineers designing with Xilinix 2.5-V and 1.8-V Virtex multivoltage FPGA products. It provides basic information on the issues facing engineers not experienced with multivoltage type products.
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
Серия: TPS5602 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS5602IDBTR
