Datasheet Texas Instruments 66AK2E02 — Даташит
Серия66AK2E02
Многоядерная однокристальная система DSP+ARM KeyStone II (SoC)
66AK2E05/02 Multicore DSP+ARM KeyStone II System-on-Chip (SoC) datasheet
PDF, 2.0 Мб, Версия: D, Файл опубликован: 11 мар 2015
66AK2E02ABDA4
Статус продуктаВ производстве
66AK2E02ABDA4
N1
Pin1089
Package TypeABD
Package QTY40
Маркировка@2012 TI
Width (мм)27
Length (мм)27
Thickness (мм)2.98
Parameters / Models66AK2E02ABDA4
66AK2E02ABDA4
ARM CPU1 ARM Cortex-A15
ARM MHz, Max.1250,1400
ApplicationsAutomation and Process,Avionics and Defense,Communications and Telecom,Consumer Electronics,Industrial,Medical,Security,Space,Test and Measurement
DRAMDDR3,DDR3L
DSP1 C66x
DSP MHz, Max.1250,1400
EMAC2-Port 10Gb Switch,8-Port 1Gb Switch
Hardware AcceleratorsSecurity Accelerator
I2C3
On-Chip L2 Cache4096 KB (ARM Cluster),512 KB (per C66x DSP core)
Operating SystemsIntegrity,Linux,SYS/BIOS,VxWorks
Рабочий диапазон температур, Cот -40 до 100
Other On-Chip Memory2048 KB
PCI/PCIe4 PCIe Gen2
SPI3
UART, SCI2
USB2
66AK2E02ABDA4
  • Power Consumption Summary for K2E System-on-Chip (SoC) Device Family
    PDF, 65 Кб, Файл опубликован: 14 июн 2017
    This application report discusses estimating the power consumption of Texas Instruments' K2Ex Digital Signal Processors (DSP) using a provided device-specific power spreadsheet. It should be noted that the power model is applicable for all silicon revisions.
  • Clocking Spreadsheet for K2E Device Family
    PDF, 22 Кб, Файл опубликован: 26 янв 2017
    This document discusses the internal clocking architecture of Texas Instruments K2Ex Digital Signal Processors (DSP) using a provided clocking spreadsheet.The 66AK2Ex and AM5K2Ex devices have similar internal clocking architecture and peripherals except the corepac. The 66AK2Ex devices have both DSP corepac and ARM corepac, whereas, the AM5K2Ex devices have ARM corepac only.Use the K
  • Keystone EDMA FAQ
    PDF, 1.3 Мб, Файл опубликован: 1 сен 2016
    This document is a collection of frequently asked questions (FAQs) on enhanced direct memory access (EDMA) on KeyStoneв„ў I (KS1) and KeyStone II (KS2) devices, along with useful collateral and software reference links.
  • Keystone NDK FAQ
    PDF, 54 Кб, Файл опубликован: 3 окт 2016
    This document is a collection of frequently asked questions (FAQ) on running the NDK examples on the KeyStoneв„ў family of devices.
  • Keystone II DDR3 Initialization
    PDF, 73 Кб, Файл опубликован: 26 янв 2015
    This application report provides a step-to-step initialization guide for the Keystone II device DDR3 SDRAM controller.
  • Throughput Performance Guide for KeyStone II Devices (Rev. B)
    PDF, 866 Кб, Версия: B, Файл опубликован: 22 дек 2015
    This application report analyzes various performance measurements of the KeyStone II family of processors. It provides a throughput analysis of the various support peripherals to different end-points and memory access.
  • Keystone II DDR3 Debug Guide
    PDF, 143 Кб, Файл опубликован: 16 окт 2015
    This guide provides tools for use when debugging a failing DDR3 interface on a KeyStone II device.
  • Power Management of KS2 Device (Rev. C)
    PDF, 61 Кб, Версия: C, Файл опубликован: 15 июл 2016
    This application report lists the steps to enable Class 0 Temperature Compensation (Class 0 TC) mode of SmartReflexв„ў Subsystem (SRSS) module available on such devices.
  • Hardware Design Guide for KeyStone II Devices
    PDF, 1.8 Мб, Файл опубликован: 24 мар 2014
  • SERDES Link Commissioning on KeyStone I and II Devices
    PDF, 138 Кб, Файл опубликован: 13 апр 2016
    The serializer-deserializer (SerDes) performs serial-to-parallel conversions on data received from a peripheral device and parallel-to-serial conversion on data received from the CPU. This application report explains the SerDes transmit and receive parameters tuning, tools and some debug techniques for TI Keystone I and Keystone II devices.
  • PCIe Use Cases for KeyStone Devices
    PDF, 320 Кб, Файл опубликован: 13 дек 2011
  • The C6000 Embedded Application Binary Interface Migration Guide (Rev. A)
    PDF, 20 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    The C6000 compiler tools support a new ELF-based ABI named EABI. Prior to this time, the compiler only supported a single ABI, which is now named COFF ABI. The following compelling best-in-class features are available under the C6000 EABI:GeneralZero-init globals: “int gvar;” gets set to 0 before main runs.Dynamic linking: Add code to a running system.Native ROM
  • Clocking Design Guide for KeyStone Devices
    PDF, 1.5 Мб, Файл опубликован: 9 ноя 2010
  • Optimizing Loops on the C66x DSP
    PDF, 585 Кб, Файл опубликован: 9 ноя 2010
  • DDR3 Design Requirements for KeyStone Devices (Rev. B)
    PDF, 582 Кб, Версия: B, Файл опубликован: 5 июн 2014
  • Multicore Programming Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 29 авг 2012
    As application complexity continues to grow, we have reached a limit on increasing performance by merely scaling clock speed. To meet the ever-increasing processing demand, modern System-On-Chip solutions contain multiple processing cores. The dilemma is how to map applications to multicore devices. In this paper, we present a programming methodology for converting applications to run on multicore
  • TI DSP Benchmarking
    PDF, 62 Кб, Файл опубликован: 13 янв 2016
    This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms.
Серия: 66AK2E02 (1)
  • Semiconductors> Processors> Digital Signal Processors> C6000 DSP + ARM Processors> 66AK2x
На английском языке: Datasheet Texas Instruments 66AK2E02
