Datasheet ТI ADC14V155 — Даташит
| Серия | ADC14V155 |
14-битный аналого-цифровой преобразователь (АЦП), 155 MSPS, 1,1 ГГц, входная полоса пропускания
ADC14V155 14-Bit, 155 MSPS, 1.1 GHz Bandwidth A/D Converter with LVDS Outputs datasheet
PDF, 1.2 Мб, Версия: I, Файл опубликован: 19 апр 2013
| ADC14V155CISQ/NOPB | |
| N | 1 |
| Pin | 48 |
| Package Type | RHS |
| Industry STD Term | WQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | 14V155SQ |
| Width (мм) | 7 |
| Length (мм) | 7 |
| Thickness (мм) | .75 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
| Parameters / Models | ADC14V155CISQ/NOPB![]() |
| # Input Channels | 1 |
| Analog Input BW, МГц | 1100 |
| Архитектура | Pipeline |
| DNL(Max), +/-LSB | 0.55 |
| DNL(Typ), +/-LSB | 0.55 |
| ENOB, Bits | 11.5 |
| INL(Max), +/-LSB | 2.4 |
| INL(Typ), +/-LSB | 2.4 |
| Input Buffer | No |
| Input Range, Vp-p | 2 |
| Interface | DDR LVDS,Parallel LVDS |
| Рабочий диапазон температур, C | от -40 до 85 |
| Package Group | WQFN |
| Package Size: mm2:W x L, PKG | 48WQFN: 49 mm2: 7 x 7(WQFN) |
| Power Consumption(Typ), mW | 951 |
| Rating | Catalog |
| Reference Mode | Ext,Int |
| Разрешение, Bits | 14 |
| SFDR, дБ | 86.9 |
| SINAD, дБ | 71.2 |
| SNR, дБ | 71.7 |
| Sample Rate(Max), MSPS | 155 |
- High Speed ADCs with Interfacing, Driving and Clocking Schemes (Rev. A)PDF, 178 Кб, Версия: A, Файл опубликован: 26 апр 2013
This application report discusses how the performance of high-speed pipeline ADCs can be optimized bydesigning the right clock circuitry, a good analog input network, as well as how to get the data at thesehigh speeds undistorted from the ADC onto an FPGA or ASIC.
Серия: ADC14V155 (1)
- Semiconductors> Data Converters> Analog-to-Digital Converters (ADCs)> High Speed ADCs (>10MSPS)
