Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI ADS114S06IPBSR — Даташит
СерияADS114S06
МодельADS114S06IPBSR
Datasheet Texas Instruments ADS114S06IPBSR
16-разрядный 6-канальный дельта-сигма АЦП с частотой дискретизации 4 кГц, PGA и опорным напряжением для прецизионных измерений датчиков 32-TQFP от -50 до 125
ADS114S0x Low-Power, Low-Noise, Highly Integrated, 6- and 12-Channel, 4-kSPS, 16-Bit, Delta-Sigma ADC with PGA and Voltage Reference datasheet
PDF, 2.4 Мб, Версия: A, Файл опубликован: 13 июн 2017
  • Low-Cost Single-Chip Diff Temp Measurement Solution Using Delta-Sigma ADCs (Rev. A)
    PDF, 486 Кб, Версия: A, Файл опубликован: 4 май 2018
  • RTD Ratiometric Measurements and Filtering Using the ADS1148 and ADS1248
    PDF, 563 Кб, Файл опубликован: 13 мар 2013
    The ADS1148 and ADS1248 family of devices are highly integrated delta-sigma (ΔΣ) converters that areoptimized for the measurement of temperature sensors including resistance temperature detectors(RTDs) thermocouples and thermistors. In a typical RTD measurement application the ADS1148 andADS1248 are configured in a ratiometric topology using the built-in IDAC current sources feeding thro
  • Example Temperature Measurement Applications Using the ADS1247 and ADS1248 (Rev. B)
    PDF, 189 Кб, Версия: B, Файл опубликован: 9 май 2016
    This document discusses the use of the ADS1247 and ADS1248 precision analog-to-digital converters (ADCs) together with a resistive temperature device (RTD) and thermocouple to measure temperature. Included are detailed examples of the most common configurations of a two-wire RTD a three-wire RTD a four-wire RTD and a thermocouple with cold junction compensation. This document provides sufficien
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS114S06IPBSR
Политика конфиденциальности
