Datasheet Texas Instruments ADS1204IRHBT — Даташит
СерияADS1204
МодельADS1204IRHBT
Четыре дельта-сигма модулятора, CLK 10 МГц, вход 0–5 В, разрешение 16 бит, 32-VQFN от -40 до 105
Four 1-Bit, 10MHz, 2nd-Order Delta-Sigma Modulators datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 18 фев 2009
АЦП азиатских производителей
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаADS1204I
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
# Input Channels4
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)4.5 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)3 +/-LSB
Input Range(Max)5 В
Тип входаDifferential,Single-Ended
Integrated FeaturesOscillator
InterfaceSerial
Multi-Channel ConfigurationSimultaneous Sampling
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 25 mm2: 5 x 5(VQFN) PKG
Power Consumption(Typ)122 mW
Reference ModeExt,Int
Разрешение16 Bits
SINAD89 дБ
SNR89 дБ
Sample Rate (max)40kSPS SPS
Sample Rate(Max)0.04 MSPS
THD(Typ)-96 дБ
  • Evaluation Modules & Boards: AMC1210MB-EVM
    AMC1210 Mother Board
  • Using the ADS1202 Reference Design
    PDF, 448 Кб, Файл опубликован: 19 ноя 2003
    This application report describes the characteristics, operation, and use of the ADS1202 reference design. It includes two isolated ADS1202 circuits for a variety of applications and a SincВі filter implemented in a XilinxВ® XC2S150 field-programmable gate array. Optional optocouplers provide addtional isolation. A complete circuit description and schematic diagram are included.
  • Combining ADS1202 with FPGA Digital Filter for Current Msrmnt in Motor Cntrl App
    PDF, 375 Кб, Файл опубликован: 28 апр 2003
    The ADS1202 is a precision, 80dB dynamic range, delta-sigma(О”ОЈ) modulator operating from a single +5V supply. The differential inputs are ideal for direct connections to transducers or low-level signals, such as shunt resistors. With the appropriate digital filter and modulator rate, the device can be used to achieve 15-bit analog-to-digital (A/D) conversion with no missing codes. This
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1204 (3)
На английском языке: Datasheet Texas Instruments ADS1204IRHBT
