Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS5232 — Даташит
СерияADS5232
Двухканальный 12-разрядный аналого-цифровой преобразователь (АЦП) со скоростью 65 MSPS
Dual, 12-Bit, 65MSPS, +3.3V Analog-to-Digital Converter datasheet
PDF, 640 Кб, Версия: A, Файл опубликован: 28 мар 2006
ADS5232IPAGADS5232IPAGT
N12
Pin6464
Package TypePAGPAG
Industry STD TermTQFPTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY160250
CarrierJEDEC TRAY (10+1)SMALL T&R
МаркировкаADS5232IPAGADS5232IPAG
Width (мм)1010
Length (мм)1010
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsADS5232IPAG
ADS5232IPAG
ADS5232IPAGT
ADS5232IPAGT
# Input Channels22
Analog Input BW, МГц300
Analog Input BW(MHz)300
Approx. Price (US$)19.95 | 1ku
АрхитектураPipelinePipeline
DNL(Max), +/-LSB0.9
DNL(Max)(+/-LSB)0.9
DNL(Typ), +/-LSB0.3
DNL(Typ)(+/-LSB)0.3
ENOB, Bits11.3
ENOB(Bits)11.3
INL(Max), +/-LSB2.5
INL(Max)(+/-LSB)2.5
INL(Typ), +/-LSB0.4
INL(Typ)(+/-LSB)0.4
Input BufferNoNo
Input Range, Vp-p2
Input Range(Vp-p)2
InterfaceParallel CMOSParallel CMOS
Рабочий диапазон температур, Cот -40 до 85
Operating Temperature Range(C)-40 to 85
Package GroupTQFPTQFP
Package Size: mm2:W x L, PKG64TQFP: 144 mm2: 12 x 12(TQFP)
Package Size: mm2:W x L (PKG)64TQFP: 144 mm2: 12 x 12(TQFP)
Power Consumption(Typ), mW335
Power Consumption(Typ)(mW)335
RatingCatalogCatalog
Reference ModeExt,IntExt
Int
Разрешение, Bits12
Resolution(Bits)12
SFDR, дБ86
SFDR(dB)86
SINAD, дБ70.3
SINAD(dB)70.3
SNR, дБ70.7
SNR(dB)70.7
Sample Rate(Max), MSPS65
Sample Rate(Max)(MSPS)65
RoHSСовместимСовместим
  • CDCE62005 as Clock Solution for High-Speed ADCs
    PDF, 805 Кб, Файл опубликован: 4 сен 2008
    TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements
  • Design Considerations for Avoiding Timing Errors during High-Speed ADC, LVDS Dat (Rev. A)
    PDF, 2.0 Мб, Версия: A, Файл опубликован: 22 май 2015
  • Why Use Oversampling when Undersampling Can Do the Job? (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 19 июл 2013
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
Серия: ADS5232 (2)
  • Semiconductors> Data Converters> Analog-to-Digital Converters (ADCs)> High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments ADS5232
