Datasheet Texas Instruments ADS58C20IPFP — Даташит
Серия | ADS58C20 |
Модель | ADS58C20IPFP |
Двухканальный приемник IF BTS с обработкой сигналов для многорежимных сетей 3G+LTE+GSM 80-HTQFP от -40 до 85
ADS58C20 and ADS58C23 Features datasheet
PDF, 695 Кб, Файл опубликован: 30 июн 2011
Pin | 80 |
Package Type | PFP |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 96 |
Carrier | JEDEC TRAY (10+1) |
Маркировка | ADS58C20I |
Width (мм) | 12 |
Length (мм) | 12 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
# Input Channels | 2 |
Analog Input BW | 750 МГц |
Analog Voltage AVDD(Max) | 3.45 В |
Analog Voltage AVDD(Min) | 3.15 В |
Interface | Parallel LVDS |
Logic Voltage DV/DD(Max) | 2.0 В |
Logic Voltage DV/DD(Min) | 1.7 В |
Package Group | HTQFP |
Package Size: mm2:W x L | 80HTQFP: 196 mm2: 14 x 14(HTQFP) PKG |
Power Consumption(Typ) | 1630 mW |
Разрешение | 14 Bits |
SFDR(Typ) | 94 дБ |
SNR(Typ) | 77 дБ |
Sample Rate(Max) | 250 MSPS |
Special Features | Decimating Filter,Differential Inputs,Nap Mode,Out of Range Indicator,Power Down |
- Understanding Low-Amplitude Behavior of 11-bit ADCsPDF, 678 Кб, Файл опубликован: 22 окт 2011
In TI’s line of high-speed analog-to-digital converters (ADCs) with SNRBoost technology, output amplitude tends to deviate from its expected value when the applied input amplitude is small. This application note explains this phenomenon and the reasons it occurs. - High-Speed Analog-to-Digital Converter BasicsPDF, 1.1 Мб, Файл опубликован: 11 янв 2012
The goal of this document is to introduce a wide range of theories and topics that are relevant tohigh-speed analog-to-digital converters (ADC). This document provides details on sampling theorydata-sheet specifications ADC selection criteria and evaluation methods clock jitter and other commonsystem-level concerns. In addition some end-users will want to extend the performance capabil - Band-Pass Filter Design Techniques for High-Speed ADCsPDF, 733 Кб, Файл опубликован: 27 фев 2012
Several well-known methods exist for designing passive inductor-capacitor (LC) filters with resistive load terminations. However, when LC filters are used to drive the analog input pins of a high-speed analog-to-digital converter (ADC), special consideration must be given to the ADC input impedance. Not accounting for the ADC input impedance often results in a filter design that does not meet the - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS58C20 (2)
- ADS58C20IPFP ADS58C20IPFPR
- Semiconductors > RF & Microwave > Wideband Receivers
