Datasheet Texas Instruments ADS58C20 — Даташит
СерияADS58C20
Двухканальный приемник IF BTS с обработкой сигналов для многорежимных сетей 3G+LTE+GSM
ADS58C20 and ADS58C23 Features datasheet
PDF, 695 Кб, Файл опубликован: 30 июн 2011
ADS58C20IPFPADS58C20IPFPR
N12
Pin8080
Package TypePFPPFP
Industry STD TermHTQFPHTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY961000
CarrierJEDEC TRAY (10+1)LARGE T&R
МаркировкаADS58C20IADS58C20I
Width (мм)1212
Length (мм)1212
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsADS58C20IPFP
ADS58C20IPFP
ADS58C20IPFPR
ADS58C20IPFPR
# Input Channels22
Analog Input BW, МГц750750
Analog Voltage AVDD(Max), В3.453.45
Analog Voltage AVDD(Min), В3.153.15
InterfaceParallel LVDSParallel LVDS
Logic Voltage DV/DD(Max), В2.02.0
Logic Voltage DV/DD(Min), В1.71.7
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupHTQFPHTQFP
Package Size: mm2:W x L, PKG80HTQFP: 196 mm2: 14 x 14(HTQFP)80HTQFP: 196 mm2: 14 x 14(HTQFP)
Power Consumption(Typ), mW16301630
Разрешение, Bits1414
SFDR(Typ), дБ9494
SNR(Typ), дБ7777
Sample Rate(Max), MSPS250250
Special FeaturesDecimating Filter,Differential Inputs,Nap Mode,Out of Range Indicator,Power DownDecimating Filter,Differential Inputs,Nap Mode,Out of Range Indicator,Power Down
RoHSСовместимСовместим
  • Understanding Low-Amplitude Behavior of 11-bit ADCs
    PDF, 678 Кб, Файл опубликован: 22 окт 2011
    In TI’s line of high-speed analog-to-digital converters (ADCs) with SNRBoost technology, output amplitude tends to deviate from its expected value when the applied input amplitude is small. This application note explains this phenomenon and the reasons it occurs.
  • High-Speed Analog-to-Digital Converter Basics
    PDF, 1.1 Мб, Файл опубликован: 11 янв 2012
    The goal of this document is to introduce a wide range of theories and topics that are relevant tohigh-speed analog-to-digital converters (ADC). This document provides details on sampling theorydata-sheet specifications ADC selection criteria and evaluation methods clock jitter and other commonsystem-level concerns. In addition some end-users will want to extend the performance capabil
  • Band-Pass Filter Design Techniques for High-Speed ADCs
    PDF, 733 Кб, Файл опубликован: 27 фев 2012
    Several well-known methods exist for designing passive inductor-capacitor (LC) filters with resistive load terminations. However, when LC filters are used to drive the analog input pins of a high-speed analog-to-digital converter (ADC), special consideration must be given to the ADC input impedance. Not accounting for the ADC input impedance often results in a filter design that does not meet the
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS58C20 (2)
  • Semiconductors> RF & Microwave> Wideband Receivers
На английском языке: Datasheet Texas Instruments ADS58C20
