Datasheet Texas Instruments ADS58C23IPFP — Даташит
СерияADS58C23
МодельADS58C23IPFP
Двухканальный приемник IF BTS с обработкой сигналов для многорежимных сетей 3G+LTE 80-HTQFP от -40 до 85
ADS58C20 and ADS58C23 Features datasheet
PDF, 695 Кб, Файл опубликован: 30 июн 2011
Pin80
Package TypePFP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY96
CarrierJEDEC TRAY (10+1)
МаркировкаADS58C23I
Width (мм)12
Length (мм)12
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
# Input Channels2
Analog Input BW750 МГц
Analog Voltage AVDD(Max)3.45 В
Analog Voltage AVDD(Min)3.15 В
InterfaceParallel LVDS
Logic Voltage DV/DD(Max)2.0 В
Logic Voltage DV/DD(Min)1.7 В
Package GroupHTQFP
Package Size: mm2:W x L80HTQFP: 196 mm2: 14 x 14(HTQFP) PKG
Power Consumption(Typ)1630 mW
Разрешение14 Bits
SFDR(Typ)94 дБ
SNR(Typ)75 дБ
Sample Rate(Max)250 MSPS
Special FeaturesDecimating Filter,Differential Inputs,Nap Mode,Out of Range Indicator,Power Down
  • High-Speed Analog-to-Digital Converter Basics
    PDF, 1.1 Мб, Файл опубликован: 11 янв 2012
    The goal of this document is to introduce a wide range of theories and topics that are relevant tohigh-speed analog-to-digital converters (ADC). This document provides details on sampling theorydata-sheet specifications ADC selection criteria and evaluation methods clock jitter and other commonsystem-level concerns. In addition some end-users will want to extend the performance capabil
  • Band-Pass Filter Design Techniques for High-Speed ADCs
    PDF, 733 Кб, Файл опубликован: 27 фев 2012
    Several well-known methods exist for designing passive inductor-capacitor (LC) filters with resistive load terminations. However, when LC filters are used to drive the analog input pins of a high-speed analog-to-digital converter (ADC), special consideration must be given to the ADC input impedance. Not accounting for the ADC input impedance often results in a filter design that does not meet the
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS58C23 (2)
  • Semiconductors > RF & Microwave > Wideband Receivers
На английском языке: Datasheet Texas Instruments ADS58C23IPFP
