Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS58C23 — Даташит
СерияADS58C23
Двухканальный приемник IF BTS с обработкой сигналов для многорежимных сетей 3G+LTE
ADS58C20 and ADS58C23 Features datasheet
PDF, 695 Кб, Файл опубликован: 30 июн 2011
ADS58C23IPFPADS58C23IPFPR
N12
Pin8080
Package TypePFPPFP
Industry STD TermHTQFPHTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY961000
CarrierJEDEC TRAY (10+1)LARGE T&R
МаркировкаADS58C23IADS58C23I
Width (мм)1212
Length (мм)1212
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsADS58C23IPFP
ADS58C23IPFP
ADS58C23IPFPR
ADS58C23IPFPR
# Input Channels22
Analog Input BW, МГц750750
Analog Voltage AVDD(Max), В3.453.45
Analog Voltage AVDD(Min), В3.153.15
InterfaceParallel LVDSParallel LVDS
Logic Voltage DV/DD(Max), В2.02.0
Logic Voltage DV/DD(Min), В1.71.7
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupHTQFPHTQFP
Package Size: mm2:W x L, PKG80HTQFP: 196 mm2: 14 x 14(HTQFP)80HTQFP: 196 mm2: 14 x 14(HTQFP)
Power Consumption(Typ), mW16301630
Разрешение, Bits1414
SFDR(Typ), дБ9494
SNR(Typ), дБ7575
Sample Rate(Max), MSPS250250
Special FeaturesDecimating Filter,Differential Inputs,Nap Mode,Out of Range Indicator,Power DownDecimating Filter,Differential Inputs,Nap Mode,Out of Range Indicator,Power Down
RoHSСовместимСовместим
  • High-Speed Analog-to-Digital Converter Basics
    PDF, 1.1 Мб, Файл опубликован: 11 янв 2012
    The goal of this document is to introduce a wide range of theories and topics that are relevant tohigh-speed analog-to-digital converters (ADC). This document provides details on sampling theorydata-sheet specifications ADC selection criteria and evaluation methods clock jitter and other commonsystem-level concerns. In addition some end-users will want to extend the performance capabil
  • Band-Pass Filter Design Techniques for High-Speed ADCs
    PDF, 733 Кб, Файл опубликован: 27 фев 2012
    Several well-known methods exist for designing passive inductor-capacitor (LC) filters with resistive load terminations. However, when LC filters are used to drive the analog input pins of a high-speed analog-to-digital converter (ADC), special consideration must be given to the ADC input impedance. Not accounting for the ADC input impedance often results in a filter design that does not meet the
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS58C23 (2)
  • Semiconductors> RF & Microwave> Wideband Receivers
На английском языке: Datasheet Texas Instruments ADS58C23
