Datasheet Texas Instruments ADS7843-Q1 — Даташит
СерияADS7843-Q1
Автомобильный 4-проводной контроллер сенсорного экрана
ADS7843-Q1 Touch Screen Controller datasheet
PDF, 2.0 Мб, Версия: A, Файл опубликован: 1 авг 2012
ADS7843IDBQRQ1
Статус продуктаВ производстве
ADS7843IDBQRQ1
N1
Pin16
Package TypeDBQ
Industry STD TermSSOP
Package QTY2500
МаркировкаS7843Q
Width (мм)3.9
Length (мм)4.9
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
Parameters / ModelsADS7843IDBQRQ1
ADS7843IDBQRQ1
Control InterfaceSPI
Тип входаSingle-Ended
Рабочий диапазон температур, Cот -40 до 125
Package GroupSSOP
Package Size: mm2:W x L, PKG16SSOP: 19 mm2: 3.9 x 4.9(SSOP)
RatingAutomotive
SAR ADC Resolution, Bits12
SAR Sample Rate(Max), kSPS125
Supply Voltage (Analog), Max2.7
Supply Voltage (I/O VDD), Min3.6
Touch Panel4-Wire
Vref, Int/ExtInt
ADS7843IDBQRQ1
  • Calibration in touch-screen systems
    PDF, 169 Кб, Файл опубликован: 10 авг 2007
  • Reducing Analog Input Noise in Touch Screen Systems (Rev. A)
    PDF, 535 Кб, Версия: A, Файл опубликован: 15 сен 2007
    This application report discusses some common methods for reducing noise in the analog input circuitry of a resistive touch screen controller. In terms of hardware design, PCB layout and grounding are critical; the additional noise-decoupling capacitor built into a touch screen controller input pin may also help. On the software side, several simple, widely-applied filtering algorithms are present
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7843-Q1 (1)
  • Semiconductors> Data Converters> Integrated/Special Function Data Converters> Touch Screen Controllers
На английском языке: Datasheet Texas Instruments ADS7843-Q1
Публикации по теме
