Datasheet Texas Instruments ADS7846NG4 — Даташит
СерияADS7846
МодельADS7846NG4
4-проводной контроллер сенсорного экрана 16-TSSOP от -40 до 85
Touch-Screen Controller datasheet
PDF, 1.5 Мб, Версия: H, Файл опубликован: 27 янв 2005
Pin1616
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9090
CarrierTUBETUBE
Маркировка7846NADS
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
  • Set Up and Use TSC Timings
    PDF, 271 Кб, Файл опубликован: 7 июн 2007
    This application report helps users to understand, set up, and use the programming timings in the register-based touch screen controller (TSC) devices. It displays the timings functions and discusses the effect on the system interface traffic and on the system power consumption.
  • Evaluating the ADS7846E: Using the DEM-ADS7843E/45E Evaluation Fixture
    PDF, 44 Кб, Файл опубликован: 27 сен 2000
    The ADS7846 is the next-generation version to the industry standard ADS7843 4-wire touch-screen controller. The ADS7846 is 100% pin-compatible with the existing ADS7843, and will drop into the same socket. This allows for easy upgrade of current applications to the new version.
  • Using the ADS7846 Touch Screen Ctrl. with the Intel SA-1110 StrongArm Processor
    PDF, 81 Кб, Файл опубликован: 19 сен 2001
    The Intel SA-1110 StrongArm processor is a popular platform for development of personal digital assistants (PDAs) and other hand-held computing devices. The human interface for these devices is generally a touch screen. This application report provides information on connecting the TI ADS7846 touch screen controller to an SA-1110, and provides documentation for a Windows CE driver that has been de
  • Using a touch-screen controller’s auxiliary inputs
    PDF, 149 Кб, Файл опубликован: 12 окт 2007
  • Touch Screen Controller Tips
    PDF, 86 Кб, Файл опубликован: 27 сен 2000
    The ADS7843, ADS7845, and the new ADS7846 converters all are designed for specific touch screen applications. Applications using these devices can benefit greatly from the tips presented in this application bulletin. Most of the examples discuss the ADS7843, but the techniques shown are applicable to all of the devices.
  • PCB Layout Guideline for TI Resistive TSC Devices
    PDF, 144 Кб, Файл опубликован: 4 окт 2012
  • Operation Schemes of Touch Screen Controllers
    PDF, 846 Кб, Файл опубликован: 21 май 2007
  • Reducing Analog Input Noise in Touch Screen Systems (Rev. A)
    PDF, 535 Кб, Версия: A, Файл опубликован: 15 сен 2007
    This application report discusses some common methods for reducing noise in the analog input circuitry of a resistive touch screen controller. In terms of hardware design, PCB layout and grounding are critical; the additional noise-decoupling capacitor built into a touch screen controller input pin may also help. On the software side, several simple, widely-applied filtering algorithms are present
  • Calibration in touch-screen systems
    PDF, 169 Кб, Файл опубликован: 10 авг 2007
  • Q4 2007 Issue Analog Applications Journal (Rev. A)
    PDF, 316 Кб, Версия: A, Файл опубликован: 14 ноя 2007
  • Apply TI TSC for Various and Multiple Functions
    PDF, 316 Кб, Файл опубликован: 11 дек 2006
    This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
На английском языке: Datasheet Texas Instruments ADS7846NG4
