Datasheet Texas Instruments ADS8383 — Даташит
СерияADS8383
18-битный параллельный АЦП, 500 KSPS
18-Bit, 500-kHz, Unipolar Input, Micropower Sampling ADC Converter datasheet
PDF, 926 Кб, Версия: C, Файл опубликован: 14 фев 2005
ADS8383IBPFBT
Статус продуктаВ производстве
ADS8383IBPFBT
N1
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierSMALL T&R
МаркировкаADS8383I
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Parameters / ModelsADS8383IBPFBT
ADS8383IBPFBT
# Input Channels1
Analog Voltage AVDD(Max), В5.25
Analog Voltage AVDD(Min), В4.75
АрхитектураSAR
Digital Supply(Max), В5.25
Digital Supply(Min), В2.95
INL(Max), +/-LSB4
Input Range(Max), В4.2
Тип входаPseudo-Differential,Single-Ended
Integrated FeaturesOscillator
InterfaceSPI
Multi-Channel ConfigurationN/A
Рабочий диапазон температур, Cот -40 до 85
Package GroupTQFP
Package Size: mm2:W x L, PKG48TQFP: 81 mm2: 9 x 9(TQFP)
Power Consumption(Typ), mW110
Reference ModeExt
Разрешение, Bits18
SINAD, дБ87
SNR, дБ88
Sample Rate (max), SPS500kSPS
Sample Rate(Max), MSPS0.5
THD(Typ), дБ-112
ADS8383IBPFBT
  • Interfacing the ADS8383 to TMS320C6711 DSP
    PDF, 1.3 Мб, Файл опубликован: 4 июн 2003
    This application note presents a software and hardware interface of the ADS8383 18-bit 500 kHz analog-to-digital converter to the TMS320C6711 DSP. The hardware platform used to develop this application is ADS8383EVM and TMS320C6711 DSK. The software developed reads 1024 blocks of samples continuously from ADS8383. In an effort to reduce development time, the source code is available on TI's websit
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
Серия: ADS8383 (1)
  • Semiconductors> Data Converters> Analog-to-Digital Converters (ADCs)> Precision ADCs (<=10MSPS)
На английском языке: Datasheet Texas Instruments ADS8383
