Datasheet Texas Instruments AFE58JD18 — Даташит
СерияAFE58JD18
16-Channel, Ultrasound, Analog Front-End with 140-mW/Channel Power, 0.75-nV/в€љHz.
AFE58JD18 16-Channel, Ultrasound AFE with 14-Bit, 65-MSPS or 12-Bit, 80-MSPS ADC, Passive CW Mixer, I/Q Demodulator, and LVDS, JESD204B Outputs datasheet
PDF, 866 Кб, Версия: A, Файл опубликован: 27 май 2016
AFE58JD18ZBV
Статус продуктаВ производстве
AFE58JD18ZBV
N1
Pin289
Package TypeZBV
Industry STD TermNFBGA
JEDEC CodeS-PBGA-N
Package QTY126
МаркировкаAFE58JD18
Width (мм)15
Length (мм)15
Thickness (мм)1.25
Pitch (мм).8
Max Height (мм)1.8
Parameters / ModelsAFE58JD18ZBV
AFE58JD18ZBV
# Input Channels16
Active Supply Current(Typ), мА274
InterfaceJESD
Рабочий диапазон температур, Cот -40 до 85
Package GroupNFBGA
Package Size: mm2:W x L, PKG289NFBGA: 225 mm2: 15 x 15(NFBGA)
Special FeaturesAnalog Front End (AFE)
Напряжение питания, Min3.6
AFE58JD18ZBV
  • Time Gain Control (Compensation) in Ultrasound Applications
    PDF, 319 Кб, Файл опубликован: 2 дек 2016
    This application report explains a vital functionality in Medical Ultrasound Systems called Time Gain Control or Time Gain Compensation (TGC). Starting from why TGC is important, with examples and requirements on the control signals for implementing TGC are explained in detail. The selection criteria and example circuits for external components (like Digital-to-Analog Converter (DAC) and Op-amp) a
Серия: AFE58JD18 (1)
  • Semiconductors> Sensing Products> Ultrasonic Sensing
На английском языке: Datasheet Texas Instruments AFE58JD18
