Datasheet Texas Instruments AIC111 — Даташит
СерияAIC111
Одноканальный кодек микропитания 1,3 В
IC Design Specification 1.3-V microPower(TM) DSP/uC Voice Band Audio CODEC datasheet
PDF, 316 Кб, Версия: A, Файл опубликован: 24 янв 2006
AIC111RHBAIC111RHBG4
N12
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY7373
CarrierTUBETUBE
МаркировкаAIC111AIC111
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Parameters / ModelsAIC111RHB
AIC111RHB
AIC111RHBG4
AIC111RHBG4
ADC Channels11
ADC SNR(Typ), дБ8787
Analog Inputs22
Analog Outputs22
DAC Channels11
Digital Audio InterfaceDSPDSP
Package Size: mm2:W x L, PKG32VQFN: 25 mm2: 5 x 5(VQFN)32VQFN: 25 mm2: 5 x 5(VQFN)
Sampling Rate(Max), kHz4040
RoHSСовместимСовместим
  • Efficient Resampling Filters for the AIC111
    PDF, 2.1 Мб, Файл опубликован: 25 фев 2004
    The AIC111 is an ultralow-power, fixed sample rate, sigma-delta codec with a sample rate of 40 kHz and a usable bandwidth of 10 kHz. Typically, most applications process data at sample rates of 8 kHz, 16 kHz, and 20 kHz. This requires that the DSP or microprocessor connected to the AIC111 decimate the incoming data from 40 kHz down to the required sampling frequency, and interpolate the data back
  • How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PC
    PDF, 480 Кб, Файл опубликован: 14 дек 2004
    Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1.
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
Серия: AIC111 (2)
  • Semiconductors> Audio> Audio Converters> Audio CODEC
На английском языке: Datasheet Texas Instruments AIC111
