Datasheet Texas Instruments AM1808EZCE4 — Даташит
СерияAM1808
МодельAM1808EZCE4
Процессор Sitara: ARM9, LPDDR, DDR2, дисплей, Ethernet 361-NFBGA от 0 до 90
AM1808 ARM Microprocessor datasheet
PDF, 1.9 Мб, Версия: E, Файл опубликован: 21 мар 2014
Pin361361361
Package TypeZCEZCEZCE
Industry STD TermNFBGANFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY160160160
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаAM1808EZCE456
Width (мм)131313
Length (мм)131313
Thickness (мм).89.89.89
Pitch (мм).65.65.65
Max Height (мм)1.31.31.3
ARM CPU1 ARM9
ARM MHz375,456 Max.
ApplicationsAutomotive,Communications Equipment,Enterprise Systems,Industrial,Personal Electronics
DRAMDDR2,LPDDR
Display OptionsLCD
EMAC10/100
I2C2
On-Chip L2 Cache128 KB (ARM9)
Operating SystemsAndroid,Integrity,Linux,Neutrino,VxWorks,Windows Embedded CE
Рабочий диапазон температурот 0 до 90,-40 до 105,-40 до 90 C
SPI2
UART3 SCI
USB2
    XDS200 USB Debug Probe
  • Evaluation Modules & Boards: TMDXEVMWIFI1808L
    AM18x evaluation module with Wi-Fi
  • Development Kits: TMDXLCDK138
    OMAP-L138 Development Kit (LCDK)
  • Development Kits: TMDXLCDK6748
    TMS320C6748 DSP Development Kit (LCDK)
  • Evaluation Modules & Boards: TMDSEXP1808L
    AM18x eXperimenter's Kit
  • Getting Started With the AM18x EVM or eXperimenter’s Kit
    PDF, 20 Кб, Файл опубликован: 30 мар 2010
  • Running the Metrology Demo on the SGI EVM
    PDF, 28 Кб, Файл опубликован: 27 июн 2012
    The Metrology Demo showcases the ability of the dual-core OMAP-L138 DSP+ARM processor to execute metrology functions, power analytics algorithms (FFT), and a Rogowski coil digital integrator on its TMS320C674x DSP, while at the same time running a high-level operating system (Linux) with network communication on its ARM9в„ў core. A Windows PC graphical user interface (GUI) is used to display t
  • SGI EVM Software Manual
    This article will guide you in the basic setup of the file system and Linux kernel for the Smart Grid Infrastructure (SGI) EVM. It also provides information on modifying and rebuilding the Linux kernel for your application.The SGI platform is designed for development and test of smart grid applications including: data concentrator, power protection and monitoring, power analytics, industria
  • Powering the AM1806, AM1808, and AM1810 with the TPS650061
    PDF, 461 Кб, Файл опубликован: 6 сен 2011
  • AM18xx Pin Multiplexing Utility (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 6 дек 2011
    The AM18xx devices use a great deal of internal pin multiplexing to allow the most functionality in the smallest and lowest cost package. This software allows the pin multiplexing registers of the device to be calculated with ease, as well as showing what peripherals can be used together and what devices support the peripherals that are selected. This software is useful to anyone creating a system
  • Using the AM18xx Bootloader (Rev. C)
    PDF, 1.6 Мб, Версия: C, Файл опубликован: 23 янв 2014
    This application report describes various boot mechanisms supported by the AM18xx bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, default settin
  • AM18x Power Consumption Summary
    PDF, 19 Кб, Файл опубликован: 30 авг 2010
    This article discusses the power consumption of the Texas Instruments AM18x. Power consumption on the AM18x devices are highly application-dependent. The low-core voltage and other power design optimizations allow these devices to operate with industry-leading performance, while maintaining a low power-to-performance ratio.The power data presented in this document are based on measured data w
  • WiLink 6.0 (WL1271) OpenLink Platform (Rev. A)
    PDF, 735 Кб, Версия: A, Файл опубликован: 26 апр 2011
  • OMAP-L1x8 Complementary Products
    PDF, 26 Кб, Файл опубликован: 20 июл 2009
    This article has been contributed to the TI DaVinciв„ў and OMAPв„ў Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://tiexpressdsp.com/index.php/OMAP-L1x8_Complementary_Products .This Wiki article serves as a repository of complimentary devices that ca
  • OMAP-L13x/AM1x Linux PSP Overview
    PDF, 20 Кб, Файл опубликован: 18 авг 2010
    This article has been contributed to the Texas Instrument's Embedded Processors Wiki site:http://processors.wiki.ti.com/index.php/Community_Linux_PSP_for_DA8x/OMAP-L1/AM1xThe Linux Platform Support Package (PSP) for Sitara AM1x and OMAP-L13x provides support for Linux kernel, U-Boot, UBL and
  • Powering OMAP-L132/L138, C6742/4/6, and AM18x with TPS65070 (Rev. B)
    PDF, 453 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This documents details the design consideration of a power management unit (PMU) solution for the OMAP-L132/-L138 low-power applications processors with a TPS65070 five-channel power management device.
  • High-Vin, High-Efficiency Power Solution Using DC/DC Converter With DVFS (Rev. C)
    PDF, 266 Кб, Версия: C, Файл опубликован: 29 авг 2011
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, or OMAP-L132/L138 processor. Using sequenced power supplies, this reference design describes a system having a 12-V input voltage and a high-efficiency dc/dc converter with integrated FETs and dynamic voltage and frequency scaling (DVFS) for a small, simple design.Sequenced power supply architec
  • Medium Integrated Power Solution Using a Dual DC/DC Converter and an LDO (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, or OMAP-L132/L138 processor. Using sequenced power supplies, this reference design describes a system having a 3.3-V input voltage and a high-efficiency dc/dc converter with integrated FETs for a small, simple design.Sequenced power supply architectures are becoming commonplace in high-performan
  • Simple Power Solution Using LDOs (Rev. B)
    PDF, 150 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This reference design helps those desiring to design-in the TMS320C6742, TMS320C6746, TMS320C6748, and OMAP-L132/L138. This design, employing sequenced power supplies, describes asystem with an input voltage of 3.3 V, and uses LDOs for a small, simple system.Sequenced power supply architectures are becoming commonplace in high-performance microprocessor and digital signal processor (DSP) syste
  • High-Efficiency Power Solution Using DC/DC Converters With DVFS (Rev. A)
    PDF, 161 Кб, Версия: A, Файл опубликован: 5 май 2010
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, OMAP-L138 or AM18x processor. Using sequenced power supplies, this reference design describes a system having a 12-V input voltage and a high-efficiency dc/dc converter with ntegrated FETs and dynamic voltage and frequency scaling (DVFS) for a small, simple design.Sequenced power supply archit
  • TMS320C6748/46/42 & OMAP-L1x8 USB Upstream Device Compliance Testing
    PDF, 1.1 Мб, Файл опубликован: 17 авг 2009
    This application report describes the TMS320C6748/46/42 and OMAP-L1x8 electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The on-the-go (OTG) controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS) and low-speed (LS).
  • TMS320C6748/46/42 & OMAP-L132/L138 USB Downstream Host Compliance Testing
    PDF, 3.6 Мб, Файл опубликован: 17 авг 2009
    This application report describes the TMS320C6748/46/42 and OMAP-L1x8 embedded Host electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The OTG controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS) and low-speed (LS).
  • High-Integration, High-Efficiency Power Solution Using DC/DC Converters w/DVFS (Rev. A)
    PDF, 208 Кб, Версия: A, Файл опубликован: 5 май 2010
  • TMS320C674x/OMAP-L1x USB Compliance Checklist
    PDF, 89 Кб, Файл опубликован: 12 мар 2009
    This application report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • OMAP-L1x/C674x/AM1x SOC Architecture and Throughput Overview
    PDF, 19 Кб, Файл опубликован: 12 фев 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/OMAP-L1x/C674x/AM1x_SOC_Architecture_and_Throughput_Overview. This collection of Wiki articles provide i
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Sitara Processors > ARM9 > AM1x
На английском языке: Datasheet Texas Instruments AM1808EZCE4
