Datasheet Texas Instruments AM3352BZCZA60 — Даташит
СерияAM3352
МодельAM3352BZCZA60
Процессор Sitara: ARM Cortex-A8, 1 Гбит Ethernet, дисплей 324-NFBGA от -40 до 105
AM335x Sitaraв„ў Processors datasheet
PDF, 3.2 Мб, Версия: J, Файл опубликован: 12 апр 2016
Pin324
Package TypeZCZ
Package QTY126
МаркировкаAM3352BZCZA60
Width (мм)15
Length (мм)15
Thickness (мм).9
ARM CPU1 ARM Cortex-A8
ARM MHz300,600,800,1000 Max.
ApplicationsAutomotive,Industrial,Personal Electronics
Co-ProcessorN/A s
DMIPS600,1200,1600,2000
DRAMDDR2,DDR3,DDR3L,LPDDR
Display Outputs1
EMAC2-Port 1Gb Switch
On-Chip L2 Cache256 KB (ARM Cortex-A8)
Operating SystemsAndroid,Linux,Windows Embedded CE
Рабочий диапазон температурот -40 до 125,-40 до 90,-40 до 105,0 до 90,до C
Other On-Chip Memory128 KB
Security EnablerCryptographic acceleration,Debug security,Initial secure programming,Secure boot,Secure storage,Software IP protection,Trusted execution environment
Serial I/OCAN,I2C,SPI,UART,USB
  • Daughter Cards: WL1835MODCOM8B
    WiLinkВ™ 8 Module 2.4 GHz WiFiВ® + BluetoothВ® COM8 Evaluation Module
  • Daughter Cards: WL1837MODCOM8I
    WiLinkВ™ 8 Dual Band 2.4 & 5 GHz Wi-FiВ® + BluetoothВ® COM8 Evaluation Module
  • Evaluation Modules & Boards: TMDSSK3358
    AM335x Starter Kit
  • Evaluation Modules & Boards: BEAGLEBK
    BeagleBone Black Development Board
  • Evaluation Modules & Boards: TMDXEVM3358
    AM335x Evaluation Module
  • JTAG Emulators/ Analyzers: TMDSEMU560V2STM-U
    XDS200 USB Debug Probe
  • AM335x Power Estimation Tool
    PDF, 84 Кб, Файл опубликован: 31 май 2017
    The Power Estimation ToolPower Estimation Tool (PET) allows you to gain insight into the power consumption of select Sitara processors. The tool includes the ability for you to choose multiple application scenarios and understand the power consumption as well as how advanced power saving techniques can be applied to further reduce overall power consumption.
  • AM335x Low Power Design Guide (Rev. A)
    PDF, 300 Кб, Версия: A, Файл опубликован: 28 фев 2017
    This document discusses techniques to develop a low power, low cost system based on the AM335x series processor. The goal is to explain how system design choices affect power consumption and how power consumption can vary significantly depending on how the developer’s application runs in that system under specific conditions.
  • AM335x and AM43xx Sitara Processors USB Layout Guidelines (Rev. A)
    PDF, 76 Кб, Версия: A, Файл опубликован: 21 авг 2014
    This application report discusses best-practice layout guidelines when implementing a universal serial bus (USB).
  • Processor SDK RTOS Customization: Modifying Board library to change UART instanc
    PDF, 783 Кб, Файл опубликован: 4 мар 2016
  • AM335x Reliability Considerations in PLC Applications (Rev. A)
    PDF, 112 Кб, Версия: A, Файл опубликован: 27 апр 2017
    Programmable Logic Controllers (PLC) are used as the main control in an automation system with high-reliability expectations and long life in harsh environments. Processors used in these applications require an assessment of performance verses expected power on hours to achieve the optimal performance for the application.
  • AM335x Thermal Considerations
    PDF, 16 Кб, Файл опубликован: 15 апр 2013
    This article discusses the thermal considerations of the AM335x devices. It offers guidance on analysis of the processor's thermal performance, suggests improvements for an end system to aid in overcoming some of the existing challenges of producing a good thermal design, and provides real power/thermal data measured with AM335x EVMs for user evaluation.
  • Sitara Linux ALSA DSP Microphone Array Voice Recognition
    PDF, 529 Кб, Файл опубликован: 30 июн 2017
    Voice recognition applications requiring a superior user experience typically use a number of digital signal processing algorithms to filter, clean, and enhance microphone sampled audio. Frequently these systems will employ multiple microphones where more sophisticated algorithms can be used. These systems can leverage a Texas Instruments Digital Signal Processor to offload the complex real-time c
  • PRU-ICSS Migration Guide: AM335x to AM437x
    PDF, 59 Кб, Файл опубликован: 7 апр 2017
    This migration guide details the Programmable Real-Time Unit (PRU) subsystem hardware differences and outlines software modifications required for porting PRU firmware and ARMВ® code to AM437x.
  • PRU-ICSS Migration Guide: AM335x to AM57x (Rev. A)
    PDF, 71 Кб, Версия: A, Файл опубликован: 13 июл 2017
    This software migration guide assists in porting legacy software developed for the Programmable Real-Time Unit Subsystem and Industrial Communication Subsystem (PRU-CSS) on AM335x to AM57x platforms.
  • nFBGA Packaging (Rev. B)
    PDF, 3.1 Мб, Версия: B, Файл опубликован: 13 ноя 2015
    This application report provides technical background on nFBGA packages and explains how to use them to build advanced board layouts.
  • 0.65 mm Pitch Flip Chip Ball Grid Array Package Reference Guide (Rev. A)
    PDF, 40.5 Мб, Версия: A, Файл опубликован: 9 авг 2015
  • Processor-SDK RTOS Power Management and Measurement
    PDF, 78 Кб, Файл опубликован: 2 авг 2017
    Processor-SDK RTOS provides out-of-the-box power management examples that empower customers to tailor Sitara processors’ (ARM and DSP) power-performance points per use case. You can configure all supported operating points and run CPU Idle and Dhrystone benchmarking workloads while employing a minimal kernel with real-time assurance. This application report provides an overview of the Processor-SD
  • PRU-ICSS Feature Comparison
    PDF, 29 Кб, Файл опубликован: 5 июн 2017
    This application report documents the feature differences between the PRU subsystems available on different TI processors.
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Sitara Processors > ARM Cortex-A8 > AM335x
На английском языке: Datasheet Texas Instruments AM3352BZCZA60
