Datasheet Texas Instruments AM3871 — Даташит
СерияAM3871
Ситара Процессор
AM387x Sitaraв„ўARMВ® Processors datasheet
PDF, 2.5 Мб, Версия: D, Файл опубликован: 5 янв 2016
AM3871CCYE100AM3871CCYE80
N12
Pin684684
Package TypeCYECYE
Industry STD TermFCBGAFCBGA
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY6060
МаркировкаAM3871CCYE100AM3871CCYE80
Width (мм)2323
Length (мм)2323
Thickness (мм)2.52.5
Pitch (мм).8.8
Max Height (мм)3.063.06
Parameters / ModelsAM3871CCYE100
AM3871CCYE100
AM3871CCYE80
AM3871CCYE80
ARM CPU1 ARM Cortex-A81 ARM Cortex-A8
ARM MHz, Max.10001000
ApplicationsCommunications Equipment,Enterprise Systems,Industrial,Personal ElectronicsCommunications Equipment,Enterprise Systems,Industrial,Personal Electronics
CAN22
DRAMLPDDR,DDR2,DDR3LPDDR,DDR2,DDR3
Display OptionsHDVPSSHDVPSS
EMAC10/100/100010/100/1000
Graphics AccelerationN/AN/A
I2C44
On-Chip L2 Cache512 KB (ARM Cortex-A8)512 KB (ARM Cortex-A8)
Operating SystemsLinux,Windows Embedded CELinux,Windows Embedded CE
Рабочий диапазон температур, Cот 0 до 90от 0 до 90
Other On-Chip Memory128 KB128 KB
RatingCatalogCatalog
SPI44
UART, SCI66
USB22
Video Port, ConfigurableN/AN/A
RoHSСовместимСовместим
  • TMS320DM814x/AM387x Power Estimation Spreadsheet (Rev. A)
    PDF, 18 Кб, Версия: A, Файл опубликован: 10 сен 2012
    This article describes how to model power consumption for a user's application and to present some measured power scenarios for the TMS320DM814x DaVinciв„ў digital media processors and AM387x Sitaraв„ў ARMВ® microprocessors (MPUs) PG2.x and PG3.x samples using a provided power estimation spreadsheet.This article has been contributed to the TI Developer Wiki. To see the most recen
  • Canny Edge Detection Implementation on TMS320C64x/64x+ Using VLIB
    PDF, 97 Кб, Файл опубликован: 25 ноя 2009
    This application note contains instructions for implementing Canny Edge Detection algorithm using VLIB. The general ideas given here can also be applied for an application which calls a sequence of VLIB functions in a block-based manner.
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
Серия: AM3871 (2)
  • Semiconductors> Processors> Sitara Processors> ARM Cortex-A8> AM3x
На английском языке: Datasheet Texas Instruments AM3871
