Datasheet Texas Instruments AM3874CCYEA80 — Даташит
СерияAM3874
МодельAM3874CCYEA80
Процессор Sitara: ARM Cortex-A8, HDMI, 3D-графика 684-FCBGA от -40 до 105
AM387x Sitaraв„ўARMВ® Processors datasheet
PDF, 2.5 Мб, Версия: D, Файл опубликован: 5 янв 2016
30 предложений от 18 поставщиков
IC MPU SITARA 800MHZ 684FCBGA. ARM® Cortex®-A8 Microprocessor IC SitaraTM 1 Core, 32-Bit 800MHz 684-FCBGA (23x23). Embedded - Microprocessors
AM3874CCYEA80
от 1 750 ₽
AM3874CCYEA80
4 189 ₽
AM3874CCYEA80
6 364 ₽
AM3874CCYEA80
Pin684
Package TypeCYE
Industry STD TermFCBGA
JEDEC CodeS-PBGA-N
Package QTY60
МаркировкаAM3874CCYEA80
Width (мм)23
Length (мм)23
Thickness (мм)2.5
Pitch (мм).8
Max Height (мм)3.06
ARM CPU1 ARM Cortex-A8
ARM MHz1000 Max.
ApplicationsCommunications Equipment,Enterprise Systems,Industrial,Personal Electronics
CAN2
DRAMLPDDR,DDR2,DDR3
Display OptionsHDVPSS
EMAC10/100/1000
Graphics Acceleration1 3D
I2C4
On-Chip L2 Cache512 KB (ARM Cortex-A8)
Operating SystemsLinux,Windows Embedded CE
Рабочий диапазон температурот -40 до 105,0 до 90 C
Other On-Chip Memory128 KB
SPI4
UART6 SCI
USB2
Video Port1 HDMI TX,2 Input,2 Output,2 SD DACs Configurable
  • Evaluation Modules & Boards: TMDXEVM8148
    DM814x /AM387x Evaluation Module
  • JTAG Emulators/ Analyzers: TMDSEMU560V2STM-U
    XDS200 USB Debug Probe
  • TMS320DM814x/AM387x Power Estimation Spreadsheet (Rev. A)
    PDF, 18 Кб, Версия: A, Файл опубликован: 10 сен 2012
    This article describes how to model power consumption for a user's application and to present some measured power scenarios for the TMS320DM814x DaVinciв„ў digital media processors and AM387x Sitaraв„ў ARMВ® microprocessors (MPUs) PG2.x and PG3.x samples using a provided power estimation spreadsheet.This article has been contributed to the TI Developer Wiki. To see the most recen
  • Canny Edge Detection Implementation on TMS320C64x/64x+ Using VLIB
    PDF, 97 Кб, Файл опубликован: 25 ноя 2009
    This application note contains instructions for implementing Canny Edge Detection algorithm using VLIB. The general ideas given here can also be applied for an application which calls a sequence of VLIB functions in a block-based manner.
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
Серия: AM3874 (3)
  • Semiconductors > Processors > Sitara Processors > ARM Cortex-A8 > AM3x
На английском языке: Datasheet Texas Instruments AM3874CCYEA80
