Datasheet Texas Instruments AM3874BCYE80 — Даташит
СерияAM3874
МодельAM3874BCYE80
Процессор Sitara 684-FCBGA от 0 до 90
AM387x Sitaraв„ўARMВ® Processors datasheet
PDF, 2.5 Мб, Версия: D, Файл опубликован: 5 янв 2016
Pin684
Package TypeCYE
Industry STD TermFCBGA
JEDEC CodeS-PBGA-N
МаркировкаAM3874BCYE80
Width (мм)23
Length (мм)23
Thickness (мм)2.5
Pitch (мм).8
Max Height (мм)3.06
ARM CPU1 ARM Cortex-A8
ARM MHz (Max.)1000
ApplicationsCommunications Equipment
Enterprise Systems
Industrial
Personal Electronics
Approx. Price (US$)43.16 | 1ku
CAN(#)2
DRAMLPDDR
DDR2
DDR3
Display OptionsHDVPSS
EMAC10/100/1000
Graphics Acceleration1 3D
I2C4
On-Chip L2 Cache512 KB (ARM Cortex-A8)
Operating SystemsWindows Embedded CE
Linux
Operating Temperature Range(C)-40 to 105
0 to 90
Other On-Chip Memory128 KB
SPI4
UART(SCI)6
USB2
Video Port (Configurable)1 HDMI TX
2 Input
2 Output
2 SD DACs
RoHSНе совместим
  • Evaluation Modules & Boards: TMDXEVM8148
    DM814x /AM387x Evaluation Module
    XDS200 USB Debug Probe
  • TMS320DM814x/AM387x Power Estimation Spreadsheet (Rev. A)
    PDF, 18 Кб, Версия: A, Файл опубликован: 10 сен 2012
    This article describes how to model power consumption for a user's application and to present some measured power scenarios for the TMS320DM814x DaVinciв„ў digital media processors and AM387x Sitaraв„ў ARMВ® microprocessors (MPUs) PG2.x and PG3.x samples using a provided power estimation spreadsheet.This article has been contributed to the TI Developer Wiki. To see the most recen
  • Canny Edge Detection Implementation on TMS320C64x/64x+ Using VLIB
    PDF, 97 Кб, Файл опубликован: 25 ноя 2009
    This application note contains instructions for implementing Canny Edge Detection algorithm using VLIB. The general ideas given here can also be applied for an application which calls a sequence of VLIB functions in a block-based manner.
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
Серия: AM3874 (3)
  • Semiconductors > Processors > Sitara Processors > ARM Cortex-A8 > AM3x
На английском языке: Datasheet Texas Instruments AM3874BCYE80
