Datasheet Texas Instruments AM4372BZDN60 — Даташит
| Серия | AM4372 |
| Модель | AM4372BZDN60 |
Процессор Sitara: ARM Cortex-A9, безопасная загрузка 491-NFBGA от 0 до 90
AM437x Sitaraв„ў Processors datasheet
PDF, 3.0 Мб, Версия: D, Файл опубликован: 14 сен 2016
Купить AM4372BZDN60 на РадиоЛоцман.Цены — от 249 до 5 241 ₽9 предложений от 9 поставщиков SITARA CORTEX-A9 PROCESSOR. ARM® Cortex®-A9 Microprocessor IC SitaraTM 1 Core, 32-Bit 600MHz 491-NFBGA (17x17). Embedded - Microprocessors | |||
| AM4372BZDN60 Texas Instruments | 249 ₽ | ||
| AM4372BZDN60 Texas Instruments | 757 ₽ | ||
| AM4372BZDN60 Texas Instruments | по запросу | ||
| Pin | 491 |
| Package Type | ZDN |
| Package QTY | 90 |
| Carrier | JEDEC TRAY (5+1) |
| Маркировка | AM4372BZDN60 |
| Width (мм) | 17 |
| Length (мм) | 17 |
| Thickness (мм) | .9 |
| Mechanical Data | Скачать |
| ARM CPU | 1 ARM Cortex-A9 |
| ARM MHz | 600,800 Max. |
| Applications | Communications Equipment,Enterprise Systems,Industrial,Personal Electronics |
| Co-Processor | N/A s |
| DMIPS | 1500,2000 |
| DRAM | DDR3,DDR3L,LPDDR2 |
| Display Outputs | 1 |
| EMAC | 2-Port 1Gb Switch |
| Graphics Acceleration | N/A |
| Industrial Protocols | None |
| On-Chip L2 Cache | 256 KB (ARM Cortex-A9) |
| Operating Systems | Android,Integrity,Linux,Neutrino,SYS/BIOS,VxWorks,Windows Embedded CE,uC/OS |
| Рабочий диапазон температур | от -40 до 105,0 до 90 C |
| Other On-Chip Memory | 320 KB |
| Rating | Catalog |
| Security Enabler | Cryptographic acceleration,Debug security,Device identity,External memory protection,Initial secure programming,Physical security,Secure boot,Secure storage,Software IP protection,Trusted execution environment |
| Serial I/O | CAN,I2C,SPI,UART,USB |
| Video Input Ports | 1 |
- Evaluation Modules & Boards: TMDSEVM437X
AM437x Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TMDXSK437X
AM437x Starter Kit
- Sitara AM437x DDR-Less System How-To Instructions and Benchmarks (Rev. A)PDF, 252 Кб, Версия: A, Файл опубликован: 21 фев 2017
This application report describes a system running EtherCAT slave with motor control leveraging the rich feature set of the Texas Instruments Sitara AM437x processor. The application on the Sitara AM437x Industrial Development Kit (IDK) EVM is demonstrated by utilizing internal SRAM, QSPI memory and eliminating external DDR completely. Benchmarking data is presented and shows no impact of the syst - AM43xx EMIF ToolsPDF, 1.3 Мб, Файл опубликован: 1 июн 2017
At the center of every application is the need for memory. With limited on-chip processor memory, external memory serves as a solution for large software systems and data storage, and an unstable external memory interface can result in system failures or hinder software development. To prevent potential system level anomalies and ensure robust systems, hardware must be configured correctly and tes - AM43xx Power Estimation ToolPDF, 31 Кб, Файл опубликован: 7 авг 2017
The Power Estimation Tool (PET) provides insight into the power consumption of select Sitaraв„ў processors. The tool includes the ability to choose multiple application scenarios and understand the power consumption as well as how advanced power saving techniques can be applied to further reduce overall power consumption. - AM335x and AM43xx Sitara Processors USB Layout Guidelines (Rev. A)PDF, 76 Кб, Версия: A, Файл опубликован: 21 авг 2014
This application report discusses best-practice layout guidelines when implementing a universal serial bus (USB). - PRU-ICSS Migration Guide: AM335x to AM437xPDF, 59 Кб, Файл опубликован: 7 апр 2017
This migration guide details the Programmable Real-Time Unit (PRU) subsystem hardware differences and outlines software modifications required for porting PRU firmware and ARMВ® code to AM437x. - nFBGA Packaging (Rev. B)PDF, 3.1 Мб, Версия: B, Файл опубликован: 13 ноя 2015
This application report provides technical background on nFBGA packages and explains how to use them to build advanced board layouts. - 0.65 mm Pitch Flip Chip Ball Grid Array Package Reference Guide (Rev. A)PDF, 40.5 Мб, Версия: A, Файл опубликован: 9 авг 2015
- Processor-SDK RTOS Power Management and MeasurementPDF, 78 Кб, Файл опубликован: 2 авг 2017
Processor-SDK RTOS provides out-of-the-box power management examples that empower customers to tailor Sitara processors’ (ARM and DSP) power-performance points per use case. You can configure all supported operating points and run CPU Idle and Dhrystone benchmarking workloads while employing a minimal kernel with real-time assurance. This application report provides an overview of the Processor-SD - PRU-ICSS Feature ComparisonPDF, 29 Кб, Файл опубликован: 5 июн 2017
This application report documents the feature differences between the PRU subsystems available on different TI processors. - Plastic Ball Grid Array [PBGA] Application Note (Rev. B)PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
Серия: AM4372 (4)
- AM4372BZDN60 AM4372BZDN80 AM4372BZDNA60 AM4372BZDNA80
- Semiconductors > Processors > Sitara Processors > ARM Cortex-A9 > AM437x
