Datasheet Texas Instruments AM4377 — Даташит
СерияAM4377
Ситара Процессор
AM437x Sitaraв„ў Processors datasheet
PDF, 3.0 Мб, Версия: D, Файл опубликован: 14 сен 2016
AM4377BZDNA100AM4377BZDNA80AM4377BZDND100AM4377BZDND80
Статус продуктаВ производствеВ производствеВ производствеВ производстве
Доступность образцов у производителяДаДаДаДа
N1234
Pin491491491491
Package TypeZDNZDNZDNZDN
Package QTY90909090
МаркировкаAM4377BZDNA100AM4377BZDNA80AM4377BZDND100AM4377BZDND80
Width (мм)17171717
Length (мм)17171717
Thickness (мм).9.9.9.9
Parameters / ModelsAM4377BZDNA100
AM4377BZDNA100
AM4377BZDNA80
AM4377BZDNA80
AM4377BZDND100
AM4377BZDND100
AM4377BZDND80
AM4377BZDND80
ARM CPU1 ARM Cortex-A91 ARM Cortex-A91 ARM Cortex-A91 ARM Cortex-A9
ARM MHz, Max.800,1000800,1000800,1000800,1000
ApplicationsCommunications Equipment,Enterprise Systems,Industrial,Personal ElectronicsCommunications Equipment,Enterprise Systems,Industrial,Personal ElectronicsCommunications Equipment,Enterprise Systems,Industrial,Personal ElectronicsCommunications Equipment,Enterprise Systems,Industrial,Personal Electronics
Co-Processor, s4 PRU-ICSS4 PRU-ICSS4 PRU-ICSS4 PRU-ICSS
DMIPS2000,25002000,25002000,25002000,2500
DRAMDDR3,DDR3L,LPDDR2DDR3,DDR3L,LPDDR2DDR3,DDR3L,LPDDR2DDR3,DDR3L,LPDDR2
Display Outputs1111
EMAC2-Port 10/100 PRU EMAC,2-Port 1Gb Switch2-Port 10/100 PRU EMAC,2-Port 1Gb Switch2-Port 10/100 PRU EMAC,2-Port 1Gb Switch2-Port 10/100 PRU EMAC,2-Port 1Gb Switch
Graphics AccelerationN/AN/AN/AN/A
Industrial Protocols1588,BiSS,EnDat 2.2,EtherCAT,EtherNet/IP,Ethernet POWERLINK,HIPERFACE DSL,PROFIBUS,PROFINET RT/IRT,SERCOS III,Sigma Delta Filter1588,BiSS,EnDat 2.2,EtherCAT,EtherNet/IP,Ethernet POWERLINK,HIPERFACE DSL,PROFIBUS,PROFINET RT/IRT,SERCOS III,Sigma Delta Filter1588,BiSS,EnDat 2.2,EtherCAT,EtherNet/IP,Ethernet POWERLINK,HIPERFACE DSL,PROFIBUS,PROFINET RT/IRT,SERCOS III,Sigma Delta Filter1588,BiSS,EnDat 2.2,EtherCAT,EtherNet/IP,Ethernet POWERLINK,HIPERFACE DSL,PROFIBUS,PROFINET RT/IRT,SERCOS III,Sigma Delta Filter
On-Chip L2 Cache256 KB (ARM Cortex-A9)256 KB (ARM Cortex-A9)256 KB (ARM Cortex-A9)256 KB (ARM Cortex-A9)
Operating SystemsAndroid,Integrity,Linux,Neutrino,SYS/BIOS,VxWorks,Windows Embedded CEAndroid,Integrity,Linux,Neutrino,SYS/BIOS,VxWorks,Windows Embedded CEAndroid,Integrity,Linux,Neutrino,SYS/BIOS,VxWorks,Windows Embedded CEAndroid,Integrity,Linux,Neutrino,SYS/BIOS,VxWorks,Windows Embedded CE
Рабочий диапазон температур, Cот -40 до 105,-40 до 90от -40 до 105,-40 до 90от -40 до 105,-40 до 90от -40 до 105,-40 до 90
Other On-Chip Memory320 KB320 KB320 KB320 KB
RatingCatalogCatalogCatalogCatalog
Security EnablerCryptographic acceleration,Debug security,Device identity,Initial secure programming,Secure boot,Secure storage,Software IP protection,Trusted execution environmentCryptographic acceleration,Debug security,Device identity,Initial secure programming,Secure boot,Secure storage,Software IP protection,Trusted execution environmentCryptographic acceleration,Debug security,Device identity,Initial secure programming,Secure boot,Secure storage,Software IP protection,Trusted execution environmentCryptographic acceleration,Debug security,Device identity,Initial secure programming,Secure boot,Secure storage,Software IP protection,Trusted execution environment
Serial I/OCAN,I2C,SPI,UART,USBCAN,I2C,SPI,UART,USBCAN,I2C,SPI,UART,USBCAN,I2C,SPI,UART,USB
Video Input Ports1111
RoHSСовместимСовместимСовместимСовместим
  • Sitara AM437x DDR-Less System How-To Instructions and Benchmarks (Rev. A)
    PDF, 252 Кб, Версия: A, Файл опубликован: 21 фев 2017
    This application report describes a system running EtherCAT slave with motor control leveraging the rich feature set of the Texas Instruments Sitara AM437x processor. The application on the Sitara AM437x Industrial Development Kit (IDK) EVM is demonstrated by utilizing internal SRAM, QSPI memory and eliminating external DDR completely. Benchmarking data is presented and shows no impact of the syst
  • nFBGA Packaging (Rev. B)
    PDF, 3.1 Мб, Версия: B, Файл опубликован: 13 ноя 2015
    This application report provides technical background on nFBGA packages and explains how to use them to build advanced board layouts.
  • 0.65 mm Pitch Flip Chip Ball Grid Array Package Reference Guide (Rev. A)
    PDF, 40.5 Мб, Версия: A, Файл опубликован: 9 авг 2015
  • Thermal Design Guide for DSP and ARM Application Processors (Rev. A)
    PDF, 324 Кб, Версия: A, Файл опубликован: 17 авг 2016
    This application report has been compiled to provide specific information and considerations regarding thermal design requirements for all DSP and ARM-based single and multi-core processors (collectively referred to as “processors”, “System-on-chip”, or “SoC”). The information contained within this document is intended to provide a minimum level of understanding with regards to the thermal require
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors> Processors> Sitara Processors> ARM Cortex-A9> AM437x
На английском языке: Datasheet Texas Instruments AM4377
