Линейка продуктов KEEN SIDE
Datasheet Texas Instruments AM4378BZDNA80 — Даташит
СерияAM4378
МодельAM4378BZDNA80
Процессор Sitara: ARM Cortex-A9, безопасная загрузка, 3D, PRU 491-NFBGA от -40 до 105
AM437x Sitaraв„ў Processors datasheet
PDF, 3.0 Мб, Версия: D, Файл опубликован: 14 сен 2016
Pin491
Package TypeZDN
Package QTY90
МаркировкаAM4378BZDNA80
Width (мм)17
Length (мм)17
Thickness (мм).9
ARM CPU1 ARM Cortex-A9
ARM MHz800,1000 Max.
ApplicationsCommunications Equipment,Enterprise Systems,Industrial,Personal Electronics
Co-Processor4 PRU-ICSS s
DMIPS2000,2500
DRAMDDR3,DDR3L,LPDDR2
Display Outputs1
EMAC2-Port 10/100 PRU EMAC,2-Port 1Gb Switch
Graphics Acceleration1 3D
Industrial Protocols1588,BiSS,EnDat 2.2,EtherNet/IP,HIPERFACE DSL,PROFIBUS,PROFINET RT/IRT,SERCOS III,Sigma Delta Filter
On-Chip L2 Cache256 KB (ARM Cortex-A9)
Operating SystemsAndroid,Integrity,Linux,Neutrino,VxWorks,Windows Embedded CE
Рабочий диапазон температурот -40 до 105,-40 до 90,0 до 90 C
Other On-Chip Memory320 KB
Security EnablerCryptographic acceleration,Debug security,Device identity,Initial secure programming,Secure boot,Secure storage,Software IP protection,Trusted execution environment
Serial I/OCAN,I2C,SPI,UART,USB
Video Input Ports1
  • Development Kits: TMDSIDK437X
    AM437x Industrial Development Kit (IDK)
  • Evaluation Modules & Boards: TMDXSK437X
    AM437x Starter Kit
  • Evaluation Modules & Boards: TMDSEVM437X
    AM437x Evaluation Module
    XDS200 USB Debug Probe
  • Evaluation Modules & Boards: PRUCAPE
    TI PRU Cape
  • Sitara AM437x DDR-Less System How-To Instructions and Benchmarks (Rev. A)
    PDF, 252 Кб, Версия: A, Файл опубликован: 21 фев 2017
    This application report describes a system running EtherCAT slave with motor control leveraging the rich feature set of the Texas Instruments Sitara AM437x processor. The application on the Sitara AM437x Industrial Development Kit (IDK) EVM is demonstrated by utilizing internal SRAM, QSPI memory and eliminating external DDR completely. Benchmarking data is presented and shows no impact of the syst
  • AM43xx EMIF Tools
    PDF, 1.3 Мб, Файл опубликован: 1 июн 2017
    At the center of every application is the need for memory. With limited on-chip processor memory, external memory serves as a solution for large software systems and data storage, and an unstable external memory interface can result in system failures or hinder software development. To prevent potential system level anomalies and ensure robust systems, hardware must be configured correctly and tes
  • AM43xx Power Estimation Tool
    PDF, 31 Кб, Файл опубликован: 7 авг 2017
    The Power Estimation Tool (PET) provides insight into the power consumption of select Sitaraв„ў processors. The tool includes the ability to choose multiple application scenarios and understand the power consumption as well as how advanced power saving techniques can be applied to further reduce overall power consumption.
  • PRU-ICSS Migration Guide: AM335x to AM437x
    PDF, 59 Кб, Файл опубликован: 7 апр 2017
    This migration guide details the Programmable Real-Time Unit (PRU) subsystem hardware differences and outlines software modifications required for porting PRU firmware and ARMВ® code to AM437x.
  • nFBGA Packaging (Rev. B)
    PDF, 3.1 Мб, Версия: B, Файл опубликован: 13 ноя 2015
    This application report provides technical background on nFBGA packages and explains how to use them to build advanced board layouts.
  • 0.65 mm Pitch Flip Chip Ball Grid Array Package Reference Guide (Rev. A)
    PDF, 40.5 Мб, Версия: A, Файл опубликован: 9 авг 2015
  • Processor-SDK RTOS Power Management and Measurement
    PDF, 78 Кб, Файл опубликован: 2 авг 2017
    Processor-SDK RTOS provides out-of-the-box power management examples that empower customers to tailor Sitara processors’ (ARM and DSP) power-performance points per use case. You can configure all supported operating points and run CPU Idle and Dhrystone benchmarking workloads while employing a minimal kernel with real-time assurance. This application report provides an overview of the Processor-SD
  • PRU-ICSS Feature Comparison
    PDF, 29 Кб, Файл опубликован: 5 июн 2017
    This application report documents the feature differences between the PRU subsystems available on different TI processors.
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Sitara Processors > ARM Cortex-A9 > AM437x
На английском языке: Datasheet Texas Instruments AM4378BZDNA80
