Datasheet Texas Instruments XAM5718AABCXEA — Даташит
Серия | AM5718 |
Модель | XAM5718AABCXEA |
Процессор Sitara 760-FCBGA от -40 до 105
AM571x Sitara Processors Silicon Revision 2.0 datasheet
PDF, 4.2 Мб, Версия: F, Файл опубликован: 11 сен 2017
Pin | 760 |
Package Type | ABC |
Industry STD Term | FCBGA |
JEDEC Code | S-PBGA-N |
Carrier | JEDEC TRAY (5+1) |
Маркировка | XAM5718AABCXEA |
Width (мм) | 23 |
Length (мм) | 23 |
Thickness (мм) | 2.39 |
Pitch (мм) | .8 |
Max Height (мм) | 2.96 |
Mechanical Data | Скачать |
ARM CPU | 1 ARM Cortex-A15 |
ARM MHz (Max.) | 1500 |
ARM MIPS(Max.) | 5250 |
Application | Communications Equipment Enterprise Systems Industrial Personal Electronics |
Approx. Price (US$) | 30.05 | 1ku |
CAN(#) | 2 |
CSI-2 | 2 |
Co-Processor(s) | 2 ARM Cortex-M4 4 PRU-ICSS |
DMA(Ch) | 64-Ch EDMA |
DRAM | DDR3(L) |
DSP | 1 C66x |
DSP MHz (Max.) | 750 |
Display Options | 1 HDMI out 3 LCD out |
EMAC | 10/100/1000 2-Port 1Gb Switch |
General Purpose Memory | 1 16-bit (GPMC NAND flash NOR Flash SRAM) |
Graphics Acceleration | 1 3D 1 2D |
HDMI | 1 |
I2C | 5 |
IO Supply(V) | 1.8 3.3 |
Industrial Protocols | 1588 EtherCAT EtherNet/IP POWERLINK PROFIBUS PROFINET RT/IRT SERCOS III |
LCD | 3 |
MMC/SD | 4 |
McASP | 8 |
On-Chip L1 Cache | 32 KB (ARM Cortex-A15) 32 KB (C66x) |
On-Chip L2 Cache | 1 MB w/ECC (ARM Cortex-A15) 288 KB (C66x) |
Operating Systems | Android Integrity Linux Nucleus Neutrino TI-RTOS VxWorks Windows Embedded CE |
Operating Temperature Range(C) | -40 to 105 0 to 90 |
Other Hardware Acceleration | Crypto Accelerator |
Other On-Chip Memory | 512 KB w/ECC |
PCI/PCIe | 2 PCIe |
PWM(Ch) | 3 |
Package Group | FCBGA |
QSPI | 1 |
RTC | 1 |
Rating | Catalog |
SATA | 1 |
SPI | 4 |
Security Enabler | Cryptographic Acceleration Debug Security Device Identity External Memory Protection Initial Secure Programming Physical Security Secure Boot Secure Storage Software IP Protection Trusted Execution Environment |
Serial I/O | CAN I2C SPI UART USB |
UART(SCI) | 10 |
USB | 2 |
USB 2.0 | 1 |
USB 3.0 | 1 |
Video Port (Configurable) | 6+ |
Video Resolution/Frame Rate | 1080p60 |
eCAP | 3 |
eQEP | 3 |
Бессвинцовая технология (Pb Free) | Да |
- Development Kits: TMDXIDK5718
AM571x Industrial Development Kit (IDK)
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TMDSEVM572X
AM572x Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TMDSCM572X
TMDSEVM572x Camera Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Development Kits: TMDXIDK57X-LCD
AM57x IDK LCD Kit
- DSPLIB for Processor SDK RTOSPDF, 461 Кб, Файл опубликован: 4 ноя 2016
- AM572x GP EVM Power SimulationsPDF, 22.4 Мб, Файл опубликован: 8 окт 2015
The purpose of this application report is to present the flow, the environment settings and TI requirements used to perform the analysis of critical power nets of a platform using an application processor. The Power Delivery Network (PDN) performance is measured by extracting and analyzing three printed circuit board (PCB) parameters: DC resistivity, capacitor loop inductance, and broadband target - IODELAY Application Note for AM57xx Devices (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 3 авг 2017
- Code Composer Studio Device Support PackagePDF, 87 Кб, Файл опубликован: 19 ноя 2015
This document gives a brief description of download location and installation procedures of the device Chip Support Package (CSP) for Code Composer Studioв„ў (CCS). - AM572x/AM571x Compatibility Guide (Rev. C)PDF, 182 Кб, Версия: C, Файл опубликован: 22 фев 2016
This application report provides a summary of the differences between AM572x Silicon Revision 1.1/2.0 and AM571x Silicon Revision 1.0 high-performance ARMВ® devices. - AM57x Processor SDK Linux: Customization of Multicore Application to Run on a NePDF, 55 Кб, Файл опубликован: 6 окт 2016
When customers develop applications that use multiple programmable cores on the AM57x they require a clear understanding of roles and configurations of multiple software (SW) components such as IPC, CMEM, CMA, Linuxв„ў, and SYS/BIOS on slave cores, in order to arrive at correct configuration for their application. This application report describes memory utilization schemes by A15/DSP/IPU, how they - EMIF Tools (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 5 июн 2017
At the center of every application is the need for memory. With limited on-chip processor memory, external memory serves as a solution for large software systems and data storage, and an unstable external memory interface can result in system failures or hinder software development. To prevent potential system level anomalies and ensure robust systems, hardware must be configured correctly and tes - Keystone EDMA FAQPDF, 1.3 Мб, Файл опубликован: 1 сен 2016
This document is a collection of frequently asked questions (FAQs) on enhanced direct memory access (EDMA) on KeyStoneв„ў I (KS1) and KeyStone II (KS2) devices, along with useful collateral and software reference links. - AN-1281 Bumped Die (Flip Chip) Packages (Rev. A)PDF, 2.2 Мб, Версия: A, Файл опубликован: 1 май 2004
Application Note 1281 Bumped Die (Flip Chip) Packages - TI DSP BenchmarkingPDF, 62 Кб, Файл опубликован: 13 янв 2016
This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms. - Thermal Design Guide for DSP and ARM Application Processors (Rev. A)PDF, 324 Кб, Версия: A, Файл опубликован: 17 авг 2016
This application report has been compiled to provide specific information and considerations regarding thermal design requirements for all DSP and ARM-based single and multi-core processors (collectively referred to as “processors”, “System-on-chip”, or “SoC”). The information contained within this document is intended to provide a minimum level of understanding with regards to the thermal require - Plastic Ball Grid Array [PBGA] Application Note (Rev. B)PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
- High-Speed Interface Layout Guidelines (Rev. G)PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
Серия: AM5718 (7)
- AM5718AABCX AM5718AABCXA AM5718AABCXEA AM5718AABCXEQ1 AM5718AABCXQ1 XAM5718AABCXEA XAM5718ABCXE
- Semiconductors > Processors > Sitara Processors > ARM Cortex-A15 > AM57x
