Datasheet Texas Instruments XAM5728BABCXE — Даташит
СерияAM5728
МодельXAM5728BABCXE
Процессор Sitara 760-FCBGA от 0 до 90
AM572x Sitaraв„ў Processors Silicon Revision 2.0 datasheet
PDF, 4.6 Мб, Версия: C, Файл опубликован: 6 июн 2017
Pin760760
Package TypeABCABC
Industry STD TermFCBGAFCBGA
JEDEC CodeS-PBGA-NS-PBGA-N
МаркировкаSITARATMXAM5728BABCXE
Width (мм)2323
Length (мм)2323
Thickness (мм)2.392.39
Pitch (мм).8.8
Max Height (мм)2.962.96
ARM CPU2 ARM Cortex-A15
ARM MHz (Max.)1500
ARM MIPS(Max.)10500
ApplicationCommunications Equipment
Enterprise Systems
Industrial
Personal Electronics
Approx. Price (US$)40.47 | 1ku
CAN(#)2
Co-Processor(s)2 ARM Cortex-M4
4 PRU-ICSS
DMA(Ch)64-Ch EDMA
DRAMDDR3(L)
DSP2 C66x
DSP MHz (Max.)750
Display Options1 HDMI out
3 LCD out
EMAC10/100/1000
2-Port 1Gb Switch
General Purpose Memory1 16-bit (GPMC
NAND flash
NOR Flash
SRAM)
Graphics Acceleration2 3D
1 2D
HDMI1
I2C5
IO Supply(V)1.8
3.3
Industrial Protocols1588
EtherCAT
EtherNet/IP
POWERLINK
PROFIBUS
PROFINET RT/IRT
SERCOS III
LCD3
MMC/SD4
McASP8
On-Chip L1 Cache32 KB (ARM Cortex-A15)
32 KB (C66x)
On-Chip L2 Cache1 MB (ARM Cortex-A15)
288 KB (C66x)
Operating SystemsAndroid
Integrity
Linux
Nucleus
Neutrino
TI-RTOS
VxWorks
Windows Embedded CE
Operating Temperature Range(C)-40 to 105
0 to 90
Other Hardware AccelerationCrypto Accelerator
Other On-Chip Memory2.5 MB w/ECC
PCI/PCIe2 PCIe Gen 2
PWM(Ch)3
Package GroupFCBGA
QSPI1
RTC1
SATA1
SPI4
Security EnablerCryptographic Acceleration
Debug Security
Device Identity
External Memory Protection
Initial Secure Programming
Physical Security
Secure Boot
Secure Storage
Software IP Protection
Trusted Execution Environment
Serial I/OCAN
I2C
SPI
UART
USB
UART(SCI)10
USB2
USB 2.01
USB 3.01
Video Port (Configurable)6+
Video Resolution/Frame Rate1080p60
eCAP3
eQEP3
  • Development Kits: TMDXIDK5728
    AM572x Industrial Development Kit (IDK)
  • Development Kits: TMDXIDK5718
    AM571x Industrial Development Kit (IDK)
  • Evaluation Modules & Boards: TMDSEVM572X
    AM572x Evaluation Module
  • Evaluation Modules & Boards: TMDSCM572X
    TMDSEVM572x Camera Module
  • Development Kits: TMDXIDK57X-LCD
    AM57x IDK LCD Kit
  • AM572x Thermal Considerations
    PDF, 400 Кб, Файл опубликован: 6 дек 2016
    This application report discusses thermal performance of the Sitara AM572x series processors. Data presented demonstrates the effects of different thermal management strategies in terms of processor junction temperature and power consumption across CPU loading and ambient temperature.
  • TPS659037 Operation With Higher Capacitive Loading
    PDF, 811 Кб, Файл опубликован: 7 окт 2015
    This TPS659037 Operation With Higher Capacitive Loading application report addresses use-cases where external components demand a higher capacitive loading than the rating of the TPS659037 SMPS-outputs (57-ОјF maximum per phase). The specification of the device with a rating of nominal 47 ОјF and maximum of 57 ОјF holds true. Exceeding these values is at the risk of the user and requires thorough val
  • TPS659037 Design Guide
    PDF, 62 Кб, Файл опубликован: 21 сен 2015
    This application note provides guidance on schematic design and can be used as a design review of applications using the TPS659037 power management IC (PMIC). This document describes recommended external components recommended connections of select signals and contains a design checklist. Prior to using this guide TI recommends reading the user's guide TPS659037 User's Guide to Power AM572x an
  • TPS659037 Design Checklist (Rev. A)
    ZIP, 45 Кб, Версия: A, Файл опубликован: 13 янв 2016
  • DSPLIB for Processor SDK RTOS
    PDF, 461 Кб, Файл опубликован: 4 ноя 2016
  • AM572x GP EVM Power Simulations
    PDF, 22.4 Мб, Файл опубликован: 8 окт 2015
    The purpose of this application report is to present the flow, the environment settings and TI requirements used to perform the analysis of critical power nets of a platform using an application processor. The Power Delivery Network (PDN) performance is measured by extracting and analyzing three printed circuit board (PCB) parameters: DC resistivity, capacitor loop inductance, and broadband target
  • EMIF Tools (Rev. A)
    PDF, 207 Кб, Версия: A, Файл опубликован: 5 июн 2017
    At the center of every application is the need for memory. With limited on-chip processor memory, external memory serves as a solution for large software systems and data storage, and an unstable external memory interface can result in system failures or hinder software development. To prevent potential system level anomalies and ensure robust systems, hardware must be configured correctly and tes
  • AM57x Processor SDK Linux: Customization of Multicore Application to Run on a Ne
    PDF, 55 Кб, Файл опубликован: 6 окт 2016
    When customers develop applications that use multiple programmable cores on the AM57x they require a clear understanding of roles and configurations of multiple software (SW) components such as IPC, CMEM, CMA, Linuxв„ў, and SYS/BIOS on slave cores, in order to arrive at correct configuration for their application. This application report describes memory utilization schemes by A15/DSP/IPU, how they
  • Keystone EDMA FAQ
    PDF, 1.3 Мб, Файл опубликован: 1 сен 2016
    This document is a collection of frequently asked questions (FAQs) on enhanced direct memory access (EDMA) on KeyStoneв„ў I (KS1) and KeyStone II (KS2) devices, along with useful collateral and software reference links.
  • AM572x/AM571x Compatibility Guide (Rev. C)
    PDF, 182 Кб, Версия: C, Файл опубликован: 22 фев 2016
    This application report provides a summary of the differences between AM572x Silicon Revision 1.1/2.0 and AM571x Silicon Revision 1.0 high-performance ARMВ® devices.
  • Code Composer Studio Device Support Package
    PDF, 87 Кб, Файл опубликован: 19 ноя 2015
    This document gives a brief description of download location and installation procedures of the device Chip Support Package (CSP) for Code Composer Studioв„ў (CCS).
  • IODELAY Application Note for AM57xx Devices (Rev. A)
    PDF, 785 Кб, Версия: A, Файл опубликован: 3 авг 2017
  • AN-1281 Bumped Die (Flip Chip) Packages (Rev. A)
    PDF, 2.2 Мб, Версия: A, Файл опубликован: 1 май 2004
    Application Note 1281 Bumped Die (Flip Chip) Packages
  • TI DSP Benchmarking
    PDF, 62 Кб, Файл опубликован: 13 янв 2016
    This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms.
  • Thermal Design Guide for DSP and ARM Application Processors (Rev. A)
    PDF, 324 Кб, Версия: A, Файл опубликован: 17 авг 2016
    This application report has been compiled to provide specific information and considerations regarding thermal design requirements for all DSP and ARM-based single and multi-core processors (collectively referred to as “processors”, “System-on-chip”, or “SoC”). The information contained within this document is intended to provide a minimum level of understanding with regards to the thermal require
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Sitara Processors > ARM Cortex-A15 > AM57x
На английском языке: Datasheet Texas Instruments XAM5728BABCXE
