Datasheet Texas Instruments AM5K2E04XABD4 — Даташит
СерияAM5K2E04
МодельAM5K2E04XABD4
Процессор Sitara: Quad ARM Cortex-A15 1089-FCBGA от 0 до 85
AM5K2E04/02 Multicore ARM KeyStone II System-on-Chip (SoC) datasheet
PDF, 1.8 Мб, Версия: D, Файл опубликован: 11 мар 2015
Pin108910891089
Package TypeABDABDABD
Package QTY404040
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка@2012 TI1.4GHZAM5K2E04XABD
Width (мм)272727
Length (мм)272727
Thickness (мм)2.982.982.98
ARM CPU4 ARM Cortex-A15
ARM MHz1250,1400 Max.
ApplicationsIndustrial
DRAMDDR3,DDR3L
EMAC8-Port 1Gb Switch
I2C3
On-Chip L2 Cache4096 KB (ARM Cluster)
Operating SystemsSYS/BIOS,Linux,VxWorks,Integrity
Рабочий диапазон температурот -40 до 100,0 до 85 C
Other On-Chip Memory2048 KB
PCI/PCIe4 PCIe Gen2
SPI3
Serial I/OHyperlink,I2C,SPI,TSIP,UART,USB
UART2 SCI
USB2
  • Evaluation Modules & Boards: XEVMK2EX
    K2E Development Board
  • JTAG Emulators/ Analyzers: TMDSEMU560V2STM-U
    XDS200 USB Debug Probe
  • Evaluation Modules & Boards: EVMK2EX
    Статус продукта: Анонсирован (Компонент анонсирован, но еще не запущен в серийное производство. Образцы могут быть как доступны, так и нет)
  • Power Consumption Summary for K2E System-on-Chip (SoC) Device Family
    PDF, 65 Кб, Файл опубликован: 14 июн 2017
    This application report discusses estimating the power consumption of Texas Instruments' K2Ex Digital Signal Processors (DSP) using a provided device-specific power spreadsheet. It should be noted that the power model is applicable for all silicon revisions.
  • Clocking Spreadsheet for K2E Device Family
    PDF, 22 Кб, Файл опубликован: 26 янв 2017
    This document discusses the internal clocking architecture of Texas Instruments K2Ex Digital Signal Processors (DSP) using a provided clocking spreadsheet.The 66AK2Ex and AM5K2Ex devices have similar internal clocking architecture and peripherals except the corepac. The 66AK2Ex devices have both DSP corepac and ARM corepac, whereas, the AM5K2Ex devices have ARM corepac only.Use the K
  • Keystone II DDR3 Initialization
    PDF, 73 Кб, Файл опубликован: 26 янв 2015
    This application report provides a step-to-step initialization guide for the Keystone II device DDR3 SDRAM controller.
  • Throughput Performance Guide for KeyStone II Devices (Rev. B)
    PDF, 866 Кб, Версия: B, Файл опубликован: 22 дек 2015
    This application report analyzes various performance measurements of the KeyStone II family of processors. It provides a throughput analysis of the various support peripherals to different end-points and memory access.
  • Keystone II DDR3 Debug Guide
    PDF, 143 Кб, Файл опубликован: 16 окт 2015
    This guide provides tools for use when debugging a failing DDR3 interface on a KeyStone II device.
  • Power Management of KS2 Device (Rev. C)
    PDF, 61 Кб, Версия: C, Файл опубликован: 15 июл 2016
    This application report lists the steps to enable Class 0 Temperature Compensation (Class 0 TC) mode of SmartReflexв„ў Subsystem (SRSS) module available on such devices.
  • Hardware Design Guide for KeyStone II Devices
    PDF, 1.8 Мб, Файл опубликован: 24 мар 2014
  • PCIe Use Cases for KeyStone Devices
    PDF, 320 Кб, Файл опубликован: 13 дек 2011
  • The C6000 Embedded Application Binary Interface Migration Guide (Rev. A)
    PDF, 20 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    The C6000 compiler tools support a new ELF-based ABI named EABI. Prior to this time, the compiler only supported a single ABI, which is now named COFF ABI. The following compelling best-in-class features are available under the C6000 EABI:GeneralZero-init globals: “int gvar;” gets set to 0 before main runs.Dynamic linking: Add code to a running system.Native ROM
  • Clocking Design Guide for KeyStone Devices
    PDF, 1.5 Мб, Файл опубликован: 9 ноя 2010
  • Optimizing Loops on the C66x DSP
    PDF, 585 Кб, Файл опубликован: 9 ноя 2010
  • DDR3 Design Requirements for KeyStone Devices (Rev. B)
    PDF, 582 Кб, Версия: B, Файл опубликован: 5 июн 2014
  • Multicore Programming Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 29 авг 2012
    As application complexity continues to grow, we have reached a limit on increasing performance by merely scaling clock speed. To meet the ever-increasing processing demand, modern System-On-Chip solutions contain multiple processing cores. The dilemma is how to map applications to multicore devices. In this paper, we present a programming methodology for converting applications to run on multicore
  • Semiconductors > Processors > Sitara Processors > ARM Cortex-A15 > AM5K2Ex
На английском языке: Datasheet Texas Instruments AM5K2E04XABD4
