Линейка продуктов KEEN SIDE
Datasheet Texas Instruments AMC1100DUBR — Даташит
СерияAMC1100
МодельAMC1100DUBR
Precision, В±250mV Input, Basic Isolated Amplifier 8-SOP -40 to 105
AMC1100 Fully-Differential Isolation Amplifier datasheet
PDF, 1.9 Мб, Версия: A, Файл опубликован: 10 дек 2014
Package TypeDUB
Industry STD TermSOP
Package QTY350
МаркировкаAMC1100
Width (мм)6.57
Length (мм)9.5
Thickness (мм)3.3
Pitch (мм)2.54
Max Height (мм)4.85
CMTI(Min)2.5 kV/µs
Common Mode Rejection Ratio(Typ)108 дБ
Gain Non-Linearity (+/-)(Max)0.075 %
Isolation Transient Overvoltage VIOTM (Peak)4250 В
Isolation Working Voltage VIOWM (rms)800 В
Package GroupSOP
Package Size: mm2:W x L8SOP: 62 mm2: 6.57 x 9.5(SOP) PKG
Small Signal Bandwidth(Typ)100 kHz
  • Evaluation Modules & Boards: AMC1100EVM
    AMC1100 Evaluation Module
  • Replacement of Input Main Sensing Transformer in Inverters with Isolate Amplifie
    PDF, 827 Кб, Файл опубликован: 21 авг 2012
    AMC1100: Replacement of Input Main Sensing Transformer in Inverters with Isolate AMC1100 Word File
  • Interfacing a Differential-Output (Isolated) Amp to a Single-Ended Input ADC
    PDF, 177 Кб, Файл опубликован: 19 апр 2017
  • 800VA Pure Sine Wave Inverter's Reference Design (Rev. A)
    PDF, 3.1 Мб, Версия: A, Файл опубликован: 1 авг 2017
    Thisapplicationnotedescribesthe designprinciplesand the circuitoperationof the 800VApureSineWaveInverter.The pureSineWaveinverterhas variousapplicationsbecauseof its key advantagessuchas operationwith verylow harmonicdistortionand cleanpowerlike utility-suppliedelectricity,reductionin audibleandelectricalnoisein fans,fluoresce
  • Voltage Fed Full Bridge DC-DC & DC-AC Converter High-Freq Inverter Using C2000 (Rev. B)
    PDF, 358 Кб, Версия: B, Файл опубликован: 17 июл 2015
    The High-Frequency Inverter is mainly used today in uninterruptible power supply systems, AC motor drives, induction heating and renewable energy source systems. The simplest form of an inverter is the bridge-type, where a power bridge is controlled according to the sinusoidal pulse-width modulation (SPWM) principle and the resulting SPWM wave is filtered to produce the alternating output voltage.
  • Designing Low Cost Flyback Power Supply Using Boost Converter (TPS61165) for HF
    PDF, 4.2 Мб, Файл опубликован: 17 апр 2014
    TPS61165, LMR14206, TPS5401, AMC1100, TLV1117I-33, TLV1117I-50 Designing low cost flyback supply using boost converter for HF Inverter
Серия: AMC1100 (4)
  • Semiconductors > Amplifiers > Special Function Amplifiers > Isolated Amplifiers
На английском языке: Datasheet Texas Instruments AMC1100DUBR
