Datasheet Texas Instruments AMC1301DWVR — Даташит
СерияAMC1301
МодельAMC1301DWVR
Precision, В±250mV Input, 3Вµs Delay, Reinforced Isolated Amplifier 8-SOIC -40 to 125
AMC1301 Precision, В±250-mV Input, 3-µs Delay, Reinforced Isolated Amplifier datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 25 янв 2017
Package TypeDWV
Package QTY1000
МаркировкаAMC1301
Width (мм)7.5
Length (мм)5.85
Thickness (мм)2.65
Max Height (мм)2.8
CMTI(Min)15 kV/µs
Common Mode Rejection Ratio(Typ)92 дБ
Gain Non-Linearity (+/-)(Max)0.03 %
Isolation Transient Overvoltage VIOTM (Peak)7000 В
Isolation Working Voltage VIOWM (rms)1000 В
Package Size: mm2:W x L8SOIC: 67 mm2: 11.5 x 5.85(SOIC) PKG
Small Signal Bandwidth(Typ)210 kHz
  • Evaluation Modules & Boards: AMC1301EVM
    AMC1301 Evaluation Module
  • How to Optimize Performance of AMC1304/05M25 in Voltage Sensing
    PDF, 181 Кб, Файл опубликован: 31 авг 2015
  • How to Optimize Performance of AMC1304/05M05 in Voltage Sensing
    PDF, 178 Кб, Файл опубликован: 31 авг 2015
  • Thermocouple Temperature Measurements Using Isolated Amplifiers (Rev. A)
    PDF, 145 Кб, Версия: A, Файл опубликован: 11 авг 2017
    The most common thermocouple in use today is the Type K. A Type-K thermocouple is inexpensive accurate and works reliably in harsh environments. Type-K thermocouples can measure temperatures ranging from –200°C to +1250°C and have a Seebeck coefficient of S = 41 μV/K at room temperature.
  • Interfacing a Differential-Output (Isolated) Amp to a Single-Ended Input ADC
    PDF, 177 Кб, Файл опубликован: 19 апр 2017
Серия: AMC1301 (2)
  • Semiconductors > Amplifiers > Special Function Amplifiers > Isolated Amplifiers
На английском языке: Datasheet Texas Instruments AMC1301DWVR
