Datasheet ТI AMC1304M25-Q1 — Даташит
| Серия | AMC1304M25-Q1 |
Automotive Reinforced Isolated Modulator With LDO Regulator, В±250mV Input, and CMOS Interface
AMC1304x-Q1 High-Precision, Reinforced Isolated Delta-Sigma Modulators with LDO datasheet
PDF, 1.7 Мб, Файл опубликован: 9 фев 2017
| AMC1304M25QDWQ1 | AMC1304M25QDWRQ1 | |
| Статус продукта | В производстве | В производстве |
| Доступность образцов у производителя | Да | Нет |
| N | 1 | 2 |
| Pin | 16 | 16 |
| Package Type | DW | DW |
| Industry STD Term | SOIC | SOIC |
| JEDEC Code | R-PDSO-G | R-PDSO-G |
| Package QTY | 40 | 2000 |
| Carrier | TUBE | LARGE T&R |
| Маркировка | 1304M25Q1 | 1304M25Q1 |
| Width (мм) | 7.5 | 7.5 |
| Length (мм) | 10.3 | 10.3 |
| Thickness (мм) | 2.35 | 2.35 |
| Pitch (мм) | 1.27 | 1.27 |
| Max Height (мм) | 2.65 | 2.65 |
| Parameters / Models | AMC1304M25QDWQ1![]() | AMC1304M25QDWRQ1![]() |
| # Input Channels | 1 | 1 |
| Analog Voltage AVDD(Max), В | 18 | 18 |
| Analog Voltage AVDD(Min), В | 4 | 4 |
| Архитектура | Delta-Sigma | Delta-Sigma |
| CMTI(Min), kV/µs | 15 | 15 |
| Digital Supply(Max), В | 5.5 | 5.5 |
| Digital Supply(Min), В | 3 | 3 |
| INL(Max), +/-LSB | 4 | 4 |
| Input Range, Vp-p | 250mV | 250mV |
| Interface | CMOS,Serial | CMOS,Serial |
| Isolation, kV peak | 7 | 7 |
| Рабочий диапазон температур, C | от -40 до 125 | от -40 до 125 |
| Package Group | SOIC | SOIC |
| Package Size: mm2:W x L, PKG | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) |
| Power Consumption(Typ), mW | 58.9 | 58.9 |
| Rating | Automotive | Automotive |
| Разрешение, Bits | 16 | 16 |
| SFDR, дБ | 90 | 90 |
| SINAD, дБ | 84 | 84 |
| SNR, дБ | 85 | 85 |
| Sample Rate (max), SPS | 20MSPS | 20MSPS |
| Sample Rate(Max), MSPS | 20 | 20 |
| THD(Max), дБ | -80 | -80 |
| RoHS | Совместим | Совместим |
Серия: AMC1304M25-Q1 (2)
- Semiconductors> Data Converters> Analog-to-Digital Converters (ADCs)> Isolated ADCs
