Datasheet Texas Instruments AMC1306E25DWV — Даташит
| Серия | AMC1306E25 |
| Модель | AMC1306E25DWV |
Small Reinforced Isolated Modulator With В±250mV Input and Manchester-Encoded CMOS Interface 8-SOIC -40 to 125
AMC1306x Small, High-Precision, Reinforced Isolated Delta-Sigma Modulators with High CMTI datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 25 июл 2017
Купить AMC1306E25DWV на РадиоЛоцман.Цены — от 393 до 1 340 ₽11 предложений от 11 поставщиков IC ISOLATED MOD 16BIT 78K 8SOIC. Isolated Module 16 bit 78k CMOS, Serial 8-SOIC. Data Acquisition - ADCs/DACs - Special Purpose... | |||
| AMC1306E25DWV Texas Instruments | 460 ₽ | ||
| AMC1306E25DWV Texas Instruments | 550 ₽ | ||
| AMC1306E25DWV Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | DWV |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 64 |
| Carrier | TUBE |
| Маркировка | 1306E25 |
| Width (мм) | 7.5 |
| Length (мм) | 5.85 |
| Thickness (мм) | 2.65 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.8 |
| Mechanical Data | Скачать |
| # Input Channels | 1 |
| Analog Voltage AVDD(Max) | 5.5 В |
| Analog Voltage AVDD(Min) | 3 В |
| Архитектура | Delta-Sigma |
| CMTI(Min) | 50 kV/µs |
| Digital Supply(Max) | 5.5 В |
| Digital Supply(Min) | 2.7 В |
| INL(Max) | 4 +/-LSB |
| Input Range | 250mV Vp-p |
| Interface | Serial CMOS |
| Isolation | 7 kV peak |
| Package Group | SOIC |
| Package Size: mm2:W x L | 8SOIC: 67 mm2: 11.5 x 5.85(SOIC) PKG |
| Power Consumption(Typ) | 45 mW |
| Rating | Catalog |
| Разрешение | 16 Bits |
| SFDR | 83 дБ |
| SINAD | 81.9 дБ |
| SNR | 82 дБ |
| Частота выборки | 21 MSPS |
| Sample Rate (max) | 21MSPS SPS |
| Sample Rate(Max) | 21 MSPS |
| THD(Max) | -85 дБ |
- Evaluation Modules & Boards: AMC1306EVM
AMC1306 Small Reinforced Isolated Delta-Sigma Modulator Evaluation Module
Серия: AMC1306E25 (2)
- AMC1306E25DWV AMC1306E25DWVR
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > Isolated ADCs
