Datasheet Texas Instruments AMC6821-Q1 — Даташит
| Серия | AMC6821-Q1 |
Мониторинг автомобильной температуры и управление вентилятором
Intelligent Temperature Monitor and PWM Fan Controller datasheet
PDF, 1.8 Мб, Файл опубликован: 17 июн 2009
| AMC6821SQDBQRQ1 | |
| AMC6821SQDBQRQ1 | |
| N | 1 |
| Pin | 16 |
| Package Type | DBQ |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | C6821Q |
| Width (мм) | 3.9 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.5 |
| Pitch (мм) | .64 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Parameters / Models | AMC6821SQDBQRQ1![]() |
| Analog Inputs | 1 |
| Fan Control Method | Linear |
| Fan Control Output, s | 1 PWM |
| Fan Speed Inputs | 1 |
| Fan Speed Measurement Accuracy, % | 6 |
| GPIOs | PWM, TACH, OVR, THERM, FANFAULT |
| Interface Type | SMBus |
| Interrupt Outputs, Count | 1 |
| No. of Temperature Sensors | 2 |
| PWM Duty Cycle Resolution, bits | 8 |
| Package Group | SSOP |
| Package Size: mm2:W x L, PKG | 16SSOP: 19 mm2: 3.9 x 4.9(SSOP) |
| Собственный ток потребления, мА | 1.1 |
| Rating | Automotive |
| Supply Current(Max), мА | 2 |
| Supply Voltage(Max), В | 5.5 |
| Supply Voltage(Min), В | 2.7 |
| Temperature Sensor Accuracy, C | 2C max for +50C to +100C,3C max for -40C to +125C |
| Temperature Sensor Resolution, C | 0.125 |
| TruTherm, TM | No |
| Voltage in ADC Resolution, bits | 11 |
| AMC6821SQDBQRQ1 | |
Серия: AMC6821-Q1 (1)
- Semiconductors> Sensing Products> Monitoring & Fan Control
