Datasheet Texas Instruments BQ2013HSN-A514TRG4 — Даташит
СерияBQ2013H
МодельBQ2013HSN-A514TRG4
NiCd/NiMH/свинцово-кислотный газовый манометр для высоких скоростей разряда (>10 А), погрешности смещения Pgm и компенсации нагрузки.
Gas Gauge IC for Power-Assist Applications, BQ2013H datasheet
PDF, 830 Кб, Версия: B, Файл опубликован: 11 дек 2013
NiCd/NiMH/Lead-Acid Gas Gauge For High Discharge Rates (>10A), Pgmable Offset Error & Load Comp. 16-SOIC 0 to 70
BQ2013HSN-A514TRG4
1 217 ₽
BQ2013HSN-A514TRG4
1 217 ₽
BQ2013HSN-A514TRG4
2 412 ₽
BQ2013HSN-A514TRG4
16-SOIC от 0 до 70
Pin1616
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаA5142013H
Width (мм)3.913.91
Length (мм)9.99.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
  • Evaluation Modules & Boards: BQ2013HEVM-001
    BQ2013H Evaluation Kit for NiCd, 16.8V
  • HDQ Communication Basics (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 18 сен 2008
    This report compares the communication timing specifications for the different battery gas gauge and battery monitor products. It discusses some of the interface requirements necessary for robust HDQ communication, such as the need for a break prior to each communication, how to reliably read 16-bit dynamic values over the 8-bit bus, and the need for some noise filtering on the HDQ line. It also
  • HDQ Communication Basics for TI Battery Monitor ICs
    PDF, 60 Кб, Файл опубликован: 16 май 2001
    Most battery monitor ICs from TI, including the bq2018 and bq2019, includes a single-wire HDQ serial data interface. Host controllers, configured for either polled or interrupt processing, use the interface to access various IC registers. The purpose of this application note is to cover most of the communication related topics for these devices.
Серия: BQ2013H (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
BQ2013HSNA514TRG4, BQ2013HSN A514TRG4
На английском языке: Datasheet Texas Instruments BQ2013HSN-A514TRG4
