Datasheet Texas Instruments BQ2014HSNTR — Даташит
СерияBQ2014H
МодельBQ2014HSNTR
NiCd/NiMH газовый манометр с высокоскоростным 1-проводным интерфейсом (HDQ) и 5 светодиодными драйверами 16-SOIC от 0 до 70
Low-Cost NiCD/NiMH Gas Gauge IC datasheet
PDF, 837 Кб, Версия: A, Файл опубликован: 31 окт 2003
IC BATTERY GAS GAUGE 16-SOIC. Battery Battery Monitor IC Multi-Chemistry 16-SOIC. PMIC - Battery Management
BQ2014HSNTR
747 ₽
BQ2014HSNTR
972 ₽
727GS
BQ2014HSNTR
Hi-Tech Circuit Group
BQ2014HSNTR
Pin1616
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка2014HA509
Width (мм)3.913.91
Length (мм)9.99.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementBQ34Z100PWR-G1
Replacement CodeF
  • HDQ Communication Basics (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 18 сен 2008
    This report compares the communication timing specifications for the different battery gas gauge and battery monitor products. It discusses some of the interface requirements necessary for robust HDQ communication, such as the need for a break prior to each communication, how to reliably read 16-bit dynamic values over the 8-bit bus, and the need for some noise filtering on the HDQ line. It also
  • HDQ Communication Basics for TI Battery Monitor ICs
    PDF, 60 Кб, Файл опубликован: 16 май 2001
    Most battery monitor ICs from TI, including the bq2018 and bq2019, includes a single-wire HDQ serial data interface. Host controllers, configured for either polled or interrupt processing, use the interface to access various IC registers. The purpose of this application note is to cover most of the communication related topics for these devices.
Серия: BQ2014H (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments BQ2014HSNTR
