Datasheet Texas Instruments BQ2018TS-E1TR — Даташит
СерияBQ2018
МодельBQ2018TS-E1TR
Многохимический счетчик заряда/разряда с высокоскоростным 1-проводным интерфейсом (HDQ) 8-TSSOP от -20 до 70
Power Minder IC datasheet
PDF, 1.6 Мб, Файл опубликован: 5 сен 1999
16 предложений от 16 поставщиков
Микросхема Чип управления батареи, Battery Fuel Gauge Multi-Chemistry Charge/Discharge Counter W/ High-Speed 1-Wire I/F (HDQ) Battery Monitoring Li-Ion 8Pin TSSOP T/R...
BQ2018TS-E1TR
219 ₽
BQ2018TS-E1TR
Benchmarq
531 ₽
Элитан
BQ2018TS-E1TR
1 614 ₽
727GS
BQ2018TS-E1TR
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаBQ218
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
  • Designed to Go: Universal Battery Monitor Using the bq2018 Power Minder IC
    PDF, 553 Кб, Файл опубликован: 5 сен 1999
  • Advanced Gas Gauge Firmware Flowchart for TI Battery Monitor ICs
    PDF, 156 Кб, Файл опубликован: 28 авг 2002
    TI advanced battery-monitoring ICs, such as the bq2018, bq2019, and bq2023, are designed to accurately measure the charge and discharge currents in rechargeable battery packs. Intended for pack integration, these devices contain all the necessary functions to form the basis of a comprehensive battery capacity management system in applications such as cellular phones, PDAs, Internet appliances, or
  • Gas Gauging Basics Using TI Battery Monitor ICs (Rev. A)
    PDF, 252 Кб, Версия: A, Файл опубликован: 17 окт 2003
    To solve the challenges of precise capacity tracking and monitoring, Texas Instruments has developed a family of accurate battery monitor devices. These devices use the coulomb counting method in order to provide the user with accurate and reliable information about the battery?s state of charge. The purpose of this report is to provide the basics of building an accurate gas-gauging feature using
  • Advanced Gas Gauge Host Firmware for TI Battery Monitor ICs
    PDF, 150 Кб, Файл опубликован: 16 май 2001
    TI advanced battery monitoring ICs, such as the bq2018, bq2019 and bq2023, are designed to accurately measure the charge and discharge currents in rechargeable battery packs. Intended for pack integration, these devices contain all the necessary functions to form the basis of a comprehensive battery capacity management system in applications such as cellular phones, PDA's, internet appliances, or
  • HDQ Communication Basics for TI Battery Monitor ICs
    PDF, 60 Кб, Файл опубликован: 16 май 2001
    Most battery monitor ICs from TI, including the bq2018 and bq2019, includes a single-wire HDQ serial data interface. Host controllers, configured for either polled or interrupt processing, use the interface to access various IC registers. The purpose of this application note is to cover most of the communication related topics for these devices.
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
BQ2018TSE1TR, BQ2018TS E1TR
На английском языке: Datasheet Texas Instruments BQ2018TS-E1TR
