Datasheet Texas Instruments BQ2040SN-D111G4 — Даташит
СерияBQ2040
МодельBQ2040SN-D111G4
Мультихимическая интеллектуальная аккумуляторная система (SBS), соответствующая стандарту 1.0, манометр с 4 светодиодными драйверами, 16-SOIC, от 0 до 70
Gas Gauge IC With SMBus Interface datasheet
PDF, 1.2 Мб, Файл опубликован: 5 сен 1999
Pin1616
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY4040
CarrierTUBETUBE
МаркировкаD1112040
Width (мм)3.913.91
Length (мм)9.99.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementBQ34Z100PW-G1
Replacement CodeF
  • bq2040-D111 to bq2040-C408 Change List
    PDF, 22 Кб, Файл опубликован: 20 окт 2003
    This document describes the design considerations required to change a bq2040SN-C408 design to a bq2040-D411 solution. This includes both hardware and firmware considerations. Find the latest ordering information and data sheet on the world wide web at http://power.ti.com.
  • Wide-Vin Battery-Charger Using SMBus MSP430 MCUs and bq Fuel Gauges (Rev. A)
    PDF, 1.0 Мб, Версия: A, Файл опубликован: 25 июл 2011
    This application report describes a smart-battery charger reference design with a wide-input-voltage range. The reference design implements the System Management Bus (SMBus) protocol for communication between the MSP430 microcontroller and a SMBus-compatible battery fuel gauge. The MSP430 device interrogates the fuel gauge for voltage, current, and other parameters via SMBus. It then adjusts the p
  • U-513 Using the bq2040, Smart Battery System Gas Gauge IC
    PDF, 131 Кб, Файл опубликован: 5 сен 1999
    The bq2040 Gas Gauge IC meets the requirements for systems incorporating the industry standard Smart Battery System bus and data set. It is based on Unitrode's proven technology for accurately monitoring battery capacity.In this tutorial, the user is the battery system designer who determines the configuration of a pack, not the end-user of a system. Terms from the SMB/SBD specifications are
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
BQ2040SND111G4, BQ2040SN D111G4
На английском языке: Datasheet Texas Instruments BQ2040SN-D111G4
