Datasheet Texas Instruments BQ2060SS-E411TR — Даташит
СерияBQ2060
МодельBQ2060SS-E411TR
Мультихимический газовый манометр, соответствующий стандарту SBS 1.1, с 5 светодиодными драйверами, дополнительным управлением аккумулятором 28-SSOP
SBS v1.1-Compliant Gas Gauge IC datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 13 окт 2005
Микросхема Чип управления батареи, Multi-Chemistry SBS 1.1 Compliant Gas Gauge With 5 LED Drivers, Additional Battery Mgmt Control 28-SSOP
BQ2060SS-E411TR
868 ₽
BQ2060SS-E411TR
1 644 ₽
Элитан
BQ2060SS-E411TR
2 535 ₽
727GS
BQ2060SS-E411TR
Pin2828
Package TypeDBQDBQ
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка2060SSE411
Width (мм)3.93.9
Length (мм)9.99.9
Thickness (мм)1.51.5
Pitch (мм).64.64
Max Height (мм)1.751.75
  • Configuring the bq2060 and bq2060a EEPROMs
    PDF, 407 Кб, Файл опубликован: 8 окт 2003
    Charging, discharging, and the entire battery system can be complex and difficult to understand. Accurately measuring energy in and out of this battery system is just as complex. The bq2060/A was developed with extensive, sophisticated functions and algorithms to measure energy transfer throughout a wide range of applications with accuracy. Thus, configuring the bq2060 for the exact battery specif
  • Using Advanced Features of the bq2060 Gas Gauge IC
    PDF, 225 Кб, Файл опубликован: 6 фев 2004
    The bq2060 is a Smart Battery System (SBS) 1.1-compliant gas-gauge IC for battery-pack or in-system installation. It maintains an accurate record of available charge in rechargeable NiCd, NiMH, Li-ion, lead acid, and other battery chemistries. This application note provides additional information and recommendations for voltage-to-frequency converter offset calibration and digital-filter threshold
  • HDQ Communication Basics for TI Battery Monitor ICs
    PDF, 60 Кб, Файл опубликован: 16 май 2001
    Most battery monitor ICs from TI, including the bq2018 and bq2019, includes a single-wire HDQ serial data interface. Host controllers, configured for either polled or interrupt processing, use the interface to access various IC registers. The purpose of this application note is to cover most of the communication related topics for these devices.
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
BQ2060SSE411TR, BQ2060SS E411TR
На английском языке: Datasheet Texas Instruments BQ2060SS-E411TR
