Datasheet Texas Instruments BQ20Z80-V110 — Даташит
СерияBQ20Z80-V110
Газовый манометр, соответствующий стандарту SBS 1.1, с технологией отслеживания импеданса
SBS 1.1-COMPLIANT GAS GAUGE ENABLED W/IMPEDANCE TRACK TECHNOLOGY FOR USE W/bq29 datasheet
PDF, 1.1 Мб, Файл опубликован: 26 июл 2007
BQ20Z80DBTR-V110
Статус продуктаНе рекомендуется для новых разработок
BQ20Z80DBTR-V110
N1
Pin38
Package TypeDBT
Industry STD TermTSSOP
Package QTY2000
Маркировка20Z80DBT
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
BQ20Z80DBTR-V110
  • Cell-type Specific Settings for Cell Imbalance Permanent Failure Thresholds
    PDF, 100 Кб, Файл опубликован: 28 сен 2007
  • Evaluation 6: Using SHA-1 in bq20zxx Family of Gas Gauges
    PDF, 107 Кб, Файл опубликован: 19 ноя 2005
    The bq20zxx Impedance Trackв„ў family of gas gauge ICs includes a highly sophisticated authentication algorithm, known as SHA-1, which requires little setup and development time and provides an effective, secure battery design.
  • Production 2: Data Flash Programming/Calibrating the bq20z80 Gas Gauges (Rev. B) (Rev. B)
    PDF, 235 Кб, Версия: B, Файл опубликован: 12 янв 2010
    This application report presents a strategy for high-speed, economical calibration and data flash programming of the bq20z80 advanced gas gauge chipset family. VB6 code examples are provided, along with step-by-step instructions for preparing a golden battery pack.
  • Five to Eight-Series-Cell bq20z80 Fuel Gauge
    PDF, 997 Кб, Файл опубликован: 10 сен 2007
    Battery fuel gauging applications requiring five- to eight-series cells may not have an obvious solution. While fully functional solutions are anticipated in the future, currently available chipsets tend to address end-products where four-series cells are the maximum. This report presents an inexpensive solution, using the bq20z80 fuel gauge.
  • Impedance Track(TM) Gas Gauge for Novices
    PDF, 482 Кб, Файл опубликован: 30 янв 2006
    This application report introduces the bq20z80 Impedance Trackв„ў and bq29312A chipset gas gauge solution.
  • Operating Fuel Gauge bq20z7x/8x/9x and SMBus-Like bq24745/47/65 Chargers
    PDF, 132 Кб, Файл опубликован: 6 окт 2009
    The smart charger bq24747/765 is a high-efficiency, synchronous battery charger with an integrated input current comparator. This charger provides low component count for space constrained, multichemistry battery charging applications. SMBus input current, charge current, and input current digital-to-analog converters allow for very high regulation accuracies that the system power management micr
  • Cell Balancing Using the bq20zxx (Rev. C)
    PDF, 208 Кб, Версия: C, Файл опубликован: 12 янв 2011
    This application report discusses three types of cell imbalances that are observed in a battery pack withserially connected cells.
  • Design 3: Configuring the bq20z80 Data Flash
    PDF, 1.2 Мб, Файл опубликован: 10 ноя 2005
    This application report presents the data flash constants for configuring the bq20z80 Smart Battery System (SBS)-compliant gas gauge device. A brief explanation of each option for the various features is included.
  • Configuring the bq20z80 Data Flash
    PDF, 2.8 Мб, Файл опубликован: 15 июн 2006
    How to Configure the bq20z80
  • bq20z80 Application Book
    PDF, 7.3 Мб, Файл опубликован: 15 июн 2006
  • Data Flash Programming Using the EV Software
    PDF, 40 Кб, Файл опубликован: 15 июн 2006
  • bq20Z80-v101 to bq20z80-V102 Change List
    PDF, 48 Кб, Файл опубликован: 17 ноя 2005
    This document describes the design considerations required to change a bq20z80-V101 design to a bq20z80-V102. Find the latest ordering information and data sheet on the TI Web site.
  • bq20z80 to bq20z80-V101 Change List
    PDF, 57 Кб, Файл опубликован: 17 авг 2005
  • Updating Firmware With the bq20zxx and EVM (Rev. B)
    PDF, 54 Кб, Версия: B, Файл опубликован: 7 ноя 2006
    This application report presents the steps necessary to update the bq20z80 firmware and the EVM.
  • Exploring the bq20z80 Impedance Track Evaluation Kit (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 14 июн 2006
  • bq20z80 EVM Data Flash Settings for Num of Serial Cells/Pack Cap (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 ноя 2006
    This application report describes the configuration changes in the data flash constants in the Texas Instruments bq20z80 Gas Gauge Evaluation Software for a variety of battery-pack configurations.
  • Pack Assembly and the bq20zxx (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 7 ноя 2006
    This application report describes a recommended assembly sequence for the bq20z80-based battery pack. This procedure results in the most time-efficient setup of the battery pack. Included are steps for connecting a 4-series cell battery to the bq20z80EVM-001.
  • Thermistor Coefficient Calculator for TI Advanced Fuel Gauges
    PDF, 58 Кб, Файл опубликован: 4 окт 2006
  • Evaluation 7: Preparing Optimized Data Flash Constants (Rev. B)
    PDF, 29 Кб, Версия: B, Файл опубликован: 4 дек 2006
    Impedance Track в„ў technology allows bq20z80 fuel gauge ICs to automatically acquire and maintain parameters for battery modeling needed for continuous fuel-gauge accuracy, regardless of battery model or manufacturer. This application report discusses how to prepare optimized default flash constants for specific battery types.
  • Design 2: Avoiding ESD and EMI Problems in bq20zxx Battery Pack Electronics
    PDF, 113 Кб, Файл опубликован: 11 ноя 2005
    In an increasingly wireless world, electrostatic discharge and electromagnetic interference are both potential issues for portable battery packs. This application report discusses the causes of ESD and EMI issues in battery pack designs and offers solutions for mitigation.
  • Support of Multiple Chemistries
    PDF, 86 Кб, Файл опубликован: 15 июн 2006
  • bq20z80-V101 Temporary SBS.FullChargeCapacity() Invalid Data
    PDF, 33 Кб, Файл опубликован: 10 сен 2005
    Temporary invalid data in the SBS.FullChargeCapacity() register of the bq20z80-V1.01 could occur under rare conditions. This application report describes those conditions and the solutions.
  • Design 4: Support of Multiple Li-Ion Chemistries w/Impedance Track(TM) Gas Gauge (Rev. R)
    PDF, 87 Кб, Версия: R, Файл опубликован: 15 окт 2009
  • Evaluation 1: Feature Set Comparison Between bq2084 and bq20z80
    PDF, 147 Кб, Файл опубликован: 29 ноя 2005
    The bq20z80 differs from the bq2084 in several areas, although all bq2084 features are available in the bq20z80. Both devices support SBS1.1 with SMBus communications, but the bq20z80 has many extended SBS commands to enable additional features. The array of bq2084 safety features is expanded in the bq20z80, with a wider range of configuration options. The bq20z80 offers greater flexibility in use
  • Battery Pack Production Flow With bq20zXX
    PDF, 62 Кб, Файл опубликован: 2 авг 2006
    This application report presents a battery pack production flow diagram for bq20zXX devices and discusses each step in detail.
  • Production Flow With bq20z80 Gas Gauges
    PDF, 41 Кб, Файл опубликован: 15 июн 2006
  • Quick-Start Guide for bq20zxx Family Gas Gauges (Rev. A)
    PDF, 4.4 Мб, Версия: A, Файл опубликован: 4 сен 2007
    The intent of this application report is to give the user an overview of the design process, how to use the evaluation module and software, and to provide helpful troubleshooting techniques.This document begins with setting up the evaluation module and working with bq Evaluation Software. Several tips for troubleshooting the software connection are included, as well as navigation and what to l
  • Evaluation 3: Theory/Implementation Impedance Track Battery Fuel-Gauging Algo (Rev. B)
    PDF, 101 Кб, Версия: B, Файл опубликован: 20 дек 2006
  • bq20z80 Printed Circuit Board Layout Guide
    PDF, 198 Кб, Файл опубликован: 16 июн 2006
  • Fast Cell Balancing Using External MOSFET (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 26 янв 2009
    The need for cell balancing comes from the fact that cell-to-cell differences in self-discharge, capacity, and impedance can lead to different charge states among the cells. However, the charger terminates the charge based on the summed voltage only, which may leave some cells undercharged and others overcharged. To remedy this imbalance and to achieve the goal of having all cells reaching 100% st
Серия: BQ20Z80-V110 (1)
  • Semiconductors> Power Management> Battery Management Products> Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments BQ20Z80-V110
