Datasheet Texas Instruments BQ24050 — Даташит
СерияBQ24050
Зарядное устройство для одноэлементных литий-ионных аккумуляторов, 1 А, с автоматическим определением переменного тока/USB.
bq2405x 1-A, Single-Cell Li-Ion and Li-Pol Battery Charger With Automatic Adaptor and USB Detection datasheet
PDF, 2.2 Мб, Версия: C, Файл опубликован: 11 дек 2014
| Линейный
BQ24050DSQRBQ24050DSQT
Доступность образцов у производителяДаНет
N12
Pin1010
Package TypeDSQDSQ
Industry STD TermWSONWSON
JEDEC CodeS-PDSO-NS-PDSO-N
Package QTY3000250
CarrierLARGE T&RSMALL T&R
МаркировкаCVCCVC
Width (мм)22
Length (мм)22
Thickness (мм).75.75
Pitch (мм).4.4
Max Height (мм).8.8
Parameters / ModelsBQ24050DSQR
BQ24050DSQR
BQ24050DSQT
BQ24050DSQT
Absolute Vin (safety rating)(Max)(, В3030
Battery Charge Voltage(Max), В4.24.2
Battery Charge Voltage(Min), В4.24.2
Cell ChemistryLi-Ion/Li-PolymerLi-Ion/Li-Polymer
Charge Current(Max), A11
Control InterfaceStandalone (RC-Settable)Standalone (RC-Settable)
Control TopologyLinearLinear
Number of Series Cells11
Operating Vin(Max), В2828
Operating Vin(Min), В3.53.5
Package GroupWSONWSON
Package Size: mm2:W x L, PKGSee datasheet (WSON)See datasheet (WSON)
Special FeaturesJEITA BAT Temp Monitoring (Thermistor Pin),Temp Monitoring (Thermistor Pin),Thermal Regulation,Vin DPM (OK for Solar Power Source)JEITA BAT Temp Monitoring (Thermistor Pin),Temp Monitoring (Thermistor Pin),Thermal Regulation,Vin DPM (OK for Solar Power Source)
USB FeatureN/AN/A
RoHSСовместимСовместим
  • Automatic AC/USB Detection in bq24050/2/5 Using D+/D- pins
    PDF, 134 Кб, Файл опубликован: 25 янв 2010
    Modern day electronic devices, such as cell phones and MP3 players, can usually be powered with either an adapter or USB source through a single input connector using a mini USB cable. For a simple charger, without separate power paths for the system and the battery, the system (including the device transceiver) is powered directly from the battery. If the battery is deeply discharged, it has to
  • Charging a three-cell nickel-based battery pack with a Li-Ion charger
    PDF, 127 Кб, Файл опубликован: 26 апр 2012
  • Li-ion battery-charger solutions for JEITA compliance
    PDF, 506 Кб, Файл опубликован: 29 янв 2010
  • Selecting the Best bq2404x/5x/9x Single Cell Battery Charger for your Applicatio
    PDF, 38 Кб, Файл опубликован: 29 ноя 2012
  • 2Q 2012 Issue Analog Applications Journal
    PDF, 2.4 Мб, Файл опубликован: 26 апр 2012
  • Q1 2010 Issue Analog Applications Journal
    PDF, 2.6 Мб, Файл опубликован: 29 янв 2010
Серия: BQ24050 (2)
  • Semiconductors> Power Management> Battery Management Products> Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24050
